Trans install question
Heh guys, I've pulled my transmission (T56) to replace the clutch slave, clutch and flywheel. Now I'm trying to install the transmission and ran into a problem. The bellhousing hits the bottom of the transmission tunnel before the trans gets lined up. I know that the engine needs to be tilted back in order to have enough room to get everything to line up. I could use a floor jack against the front of the oil pan but I'm worried about cracking the block.
If you've done this before, what did you do? I'm thinking about either loosening the K-member or the engine mounts.
I just got finished up my A4 --> M6 swap, and that's how I installed the tranny ... put the bellhousing in first, then bolted to the tranny to that. Went REALLY easy compared to pulling the 4L60E.
