cross member when converting to a th400
Old 08-14-2006, 07:13 PM
mario89's Avatar
Default cross member when converting to a th400
ive heard that you can use a 6 speed cross member from like a lt1 , has anyone tried it and did it work..i dont need the torque arm bracket as my bracket is welded to the frame ties and subframe, so i just need a crossmember by itself, will that work?
Old 08-14-2006, 07:57 PM
JMBLOWNWS6's Avatar
I think you should just buy the Yank crossmember. It is great and works flawless.
Old 08-19-2006, 09:51 PM
mario89's Avatar
i dont wanna use that one, i wanna use just a plain cross memeber, without a torque are bracket, does anyone know this? will a 6 speed cross member work?
Old 08-20-2006, 01:16 AM
DanZ28's Avatar
http://www.400raptor.com/ The sell them here plain jane crossmember modded to fit with TH400.
Old 08-20-2006, 07:48 AM
Yank's Avatar
we make a crossmember for the TH400 conversion that comes with or with out the Torque arm mount
http://www.converter.cc/drivetrain.htm
You will have to rework the stock 6 speed one to get the correct engine angle for use with the TH400
Old 08-20-2006, 03:27 PM
gd1996's Avatar
Spohn sells the spacer needed to use with a stock 6 speed crossmember... but I can't see spending even that for something that easy to space on your own.
