Midwestern Members - Parts for sale!!!
View Full Version : Parts for sale!!!
NoMoreLS1
08-15-2006, 09:43 AM
The 4.11 gear for a Ford 9 inch rear end has less than 5000 miles on it and is basically brand new. No nicks or dings. This gear was professionally set up by Dan Bills of Finish Line Performance and was very quiet as you would be able to tell by the wear pattern. $110 (firm) shipped. I accept PayPal.
Thanks,
Mitch
Cmunter14@hotmail.com
NoMoreLS1
08-15-2006, 09:50 AM
Never been used... still in box. $125 shipped (48 contiguous states/ground only)
http://static.summitracing.com/global/images/prod/large/uem-kb105030-8.jpg
Please e-mail me at Cmunter14@hotmail.com
Thanks,
Mitch
Part Number UEM-KB105030-8
Bore (in): 4.030
Piston Material: Hypereutectic aluminum
Piston Style: Dome
Compression Distance (in): 1.561
Dome Height (in): 0.100
Dome Volume (cc): 0.50
Valve Reliefs: Two
Wrist Pin Style: Floating
Pin Diameter (in): 0.9272
Top Ring Thickness: 1/16 in.
Second Ring Thickness: 1/16 in.
Oil Ring Thickness: 3/16 in.
Quantity: Sold as a set of 8.
Keith Black Hypereutectic pistons are made from 390 alloy and heat-treated to T6 standards, which makes them 30 percent stronger than ordinary untreated hypereutectics. Their 100 percent CNC-machined crowns, high upper compression-ring location, gas-accumulator groove, drilled oil returns, and spiral-lock retainer grooves make these pistons outstanding for performance applications. On top of that, their lightweight rigid-rib skirt design stabilizes the piston in the bore. All of this adds up to pistons that fit tighter than forged types, provide improved oil control, reduce blowby, increase ring life, eliminate cold start-up knocking, and won't cost you an arm and a leg.
NoMoreLS1
08-15-2006, 09:52 AM
Never used and new still in the box. Part number RU-3530
Retails for $37.22 plus shipping
K&n on-line store price (http://shop.knfilters.com/KNShop/Product.aspx?pid=RU-3530)
Your's for $25 shipped. I accept PayPal.
RU-3530 Product Specifications:
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 5.375 in (137 mm)
Flange Inside Diameter: 3.75 in (95 mm)
Flange Length: 0.625 in (16 mm)
Flange Type: Centered
Height: 7 in (178 mm)
Top Outside Diameter: 4.375 in (111 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 1.34 oz (40 ml)
Flanges: 1
Inner Wire: No
Weight: 1.4 lb (0.6 kg)
Product Box Length: 11 in (279 mm)
Product Box Width: 6.5 in (165 mm)
Product Box Height: 6.5 in (165 mm)
http://shop.knfilters.com/KNShop/Images/ProductImages/Fullsize/RU-3530.jpg
Thanks,
Mitch
SmokinHot98
08-15-2006, 12:20 PM
umm what size gear is it?
NoMoreLS1
08-15-2006, 12:26 PM
Well... the moderator that combined my threads neglected to transfer that important information to the edited thread. :bang: I looked in this section and nobody else gets their threads combined. :confused: Anyway... I'll have to edit the thread. It's a 4.11 gear for a 9 inch rear end. :)
Slow Z28
08-15-2006, 03:39 PM
I did it. And it should have transfered all that information. Unless you didn't state it in the ACTUAL thread. I was asked to combine all of them, so I did.
NoMoreLS1
08-15-2006, 03:53 PM
Ahhhh... you're the guy. :) It was in the actual thread as it was copied and pasted from another post of mine. I don't like when you guys combine for sale posts as I feel that it reduces visibility for each specific item. I know that's your policy, but I don't agree with it. Oh... there are others that are posting multiple items for sale that have not been edited into one thread. :fluffy:
CrawlinWS6
08-15-2006, 04:08 PM
Mitch starting static again. :P
Slow Z28
08-15-2006, 04:10 PM
Ask one of your other buddy's with the FLP logo in the sig ;)
That's why it was done :)
PS - i'm not seeing the other multiple posts?
NoMoreLS1
08-15-2006, 04:23 PM
Phil? I'll deal with him later. :jest: You're just not looking hard enough...
Here's an example...
Z28wheels (http://www.ls1tech.com/forums/showthread.php?t=540643)
ZR1 wheels (http://www.ls1tech.com/forums/showthread.php?t=546805)
NoMoreLS1
08-15-2006, 04:25 PM
Not hardly. Just telling it like it is. :)
Slow Z28
08-15-2006, 08:24 PM
Nope, didn't see those... but thanks for pointing out. Not a mod nazi, just a light "hazing" :)
