Anyone in here running a Th350 or th400 as daily driver
Mines not really a daily driver, but I've got a Fuddle 3600. I'm not sold on this converter to be honest, so next time I'm probably going with a Yank.
Its very drivable though, it just feels alittle too loose on top than what I was expecting.
If you do alot of cruising at highway speeds your gonna miss not having od...
Location: Your girl's back door giving her the long stroke while you're at work
Will a TH350 converter bolt to the LS1 flexplate? And do you have to run a kickdown cable?
Sorry to jack your thread but I am getting ready to do the swap myself.
i am thinking about using a trans king 4000 in my Trans am with the th350
and just buy toyota for a DD
Originally Posted by Full-Force
I have a TH-350 with 3500 stall and 4.10 gears. I have a full manual valve body in mine. Put it like this. I try to stay at 50mph or less. Im having my converter restalled to about 4200.
I cruise at 60 mph on the hiway so the tach stays about 3000 RPM.
Daily driving it would not be a problem if you did not have a long commute.
That is who I bought my TH400 from. Good customer service.
heres what i run in my daily driver
*Driveline is built like the govenor of California
Built TH400
Vig 3600 non/lock
TCI Flex plate
Reverse Manual valve body
Trans Brake
B/M shifter
Built TH400
Vig 3600 non/lock
TCI Flex plate
Trans Brake
B/M shifter
Built TH400
Vig 3600 non/lock
TCI Flex plate
Trans Brake
B/M shifter
Built TH400
Vig 3600 non/lock
TCI Flex plate
Trans Brake
B/M shifter
Rossler TH400
Coan 4000 non lock
B&M Flexplate
Reverse manual valve body
Trans brake
B&M shifter.
