clutch for 600rwhp
clutch for 600rwhp
my spec 3 is slipping with 370rwhp, and really bad when i hit the nitrous(only 75shot right now mind you). it only has like 5k miles and a few track passes on street tires 2.3 60fts. whats the most inexpensive clutch that can reliably handle the power? textrilia? can i reuse my spec billet flywheel and just have it surfaced?
is it just a stage 3 or is it a stage 3+?? if its not a 3+ then i would suggest one of them, mine is holding awesome, the textralia is also a good clutch but a bit more expensive
Jeff..look into a RAM Powergrip HD. I just purchased and installed on in my 99 bolt on nitrous motor. Its supposly rated to 680hp. Good pedal, good release, im in the process of just putting some miles on it.
i used the spec5 but it seems to hame some slipping now at 10k miles and over a dozen track passes.....not a bad clutch, im probably gonna buy another 1
