Wheels & Tires - Will This work?
BirdmanLS1
08-15-2006, 05:32 PM
Im tryin to get a set of CCW 19x13 in the rear and 18x11 in the front. Will this work??? With Koni SA shocks w/ground control kit. Will be installing a 12 bolt rear end, and will have the Eradispeed+Kit. Thanks for the input.
Xsta Z 28
08-16-2006, 02:27 PM
I doubt you'd ever get 13" wide wheels to ever fit with out MAJOR mods . . .
LS69TA
08-16-2006, 03:00 PM
Probably going to have to do some major cutting of the inner fenderwells, and severely notching the LCAs or moving them inward.
BirdmanLS1
08-16-2006, 10:41 PM
Ok, I will probably go with 11 inch tires? more reasonable? Or will that require modification. What is stock? 8 inches?
SSilverSSurfer
08-16-2006, 10:43 PM
11's will be fine, mini tub for the 13's
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
