Sponsored by: DashLynx
Anybody know how to spot a rreal ss hood from a aftermarket hood ??
Old 08-15-2006, 11:47 PM
CULATR's Avatar
Default Anybody know how to spot a rreal ss hood from a aftermarket hood ??
What are the indications that tell the differance in the two hoods? Anybody know???
Old 08-16-2006, 12:00 AM
blown 346's Avatar
Overall thickness of the hood, the way it lines up with the front fenders.
On most aftermarket SS hoods, the front of the hood right near the headlights will be thick.
You will be able to spot that out easy.
Also there are numbers under the OEM SS hoods, and on the aftermarket ones there are not.
Old 08-16-2006, 12:03 AM
CULATR's Avatar
Yea i thinking so about the thickness and numbers was just being sure i had a real ss hood , i appreciate the info i just wanted to be sure i was right ........thanks
Old 08-16-2006, 09:46 AM
RGV_Z28's Avatar
Arent OEM hoods heavier than aftermarket ones also??
Old 08-16-2006, 11:10 AM
blown 346's Avatar
I have seen some aftermarket SS hoods that weight about the same. But yes most aftermarket hoods do weight less than stock.
Old 08-16-2006, 06:24 PM
GETGONE's Avatar
Easiest way to spot it is in the scoop itself. If it has the snap in plastic grill it's OEM otherwise if it has something else in there it's aftermarket. Most of the aftermarket hoods don't quite look right either. Something is slightly off from the OEM ones but I haven't been able to figure out exactly what though.
Old 08-16-2006, 10:53 PM
LvDemKings's Avatar
I'm not sure about any other brands, but I know ASCD hoods come with the same grill that the OEM ones do. Just FYI.
