headlight help
headlight help
i have the 1998+ body and my headlights rest on the bumer but also they dont tighten to a spot you can lift them freely with your hand about 1 inch and then they will just fall back down. is there a set screw missing or something.
sounds like your headlight gaers are stripped theres is a guy on ebay that sells brass replacements i just installed them on mine and they work great think theyre $80 for both lights and come with everything you need to do them
soo my light finally failed me this weekend. passenger side motor will just let the motor run but nothing. gear finally died. also why when i lock my car with my viper alarm. i had this before when the passenger side light failed once before. but the driver side will lift up about an inch and go back down when i unlock or lock it. is that becuase the wiring is into the lights to flash their bulbs and it raises them just a tad for the amount of power it gets for a split second.
