Will I need more parts for my rebuild?
Old 08-16-2006, 05:48 PM
nvmy2000ss's Avatar
Default Will I need more parts for my rebuild?
I will be purchasing the parts below for my rebuild but I am wondering if this is all I will need:
Carbon Blocker Rings
Billet 3/4 Slider Keys
Steel 3/4 Fork
Bronze 1-4 Fork Pads
New 1/2 Slider
New 3/4 Slider
The reason for rebuild is the 3/4 shift fork is bent, but I also noticed that it is almost impossible to get into reverse, not cause its hard but because I have to make sure to hold the shifter in place or it will pop out. It also tends to grind a bit. Im fairly sure thats its not hydrolics cause all of this happend at the same time I started having problems with 3rd.
Is there more damage than I think or will the sliders and blocker rings take care of my reverse problem?
Where should I look for wear on parts, most likley spots to have problems?
Do you think the reverse fork is bent or is that even possible?
Thanks for any help.
Old 08-16-2006, 09:01 PM
ls1 joe's Avatar
Probably will need a reverse slider to fix that part. The sliders tend to wear out causing popping out issues. I would go ahead and replace it just in case.
Thanks,
Amber
T56Rebuilds.com
Old 08-17-2006, 12:32 AM
GMTECH4's Avatar
mine t56 did the exact same thing. i replaced all those parts and also 3rd gear, 3/4 syncho i drove mine for a while grinding. but if yours just started then they may be ok. the teeth on mine was trashed. mine also grinded in reverse i just flipped that syncho over to the good teeth. i'd also do the drill mod and get a new slave. my i got all my part from joe @ t56rebuilds.com
Old 08-17-2006, 12:08 PM
Mike44138's Avatar
Pick up a set of new snap rings. They're cheap and the potential for damage from resizing them isn't worth it. Just finishing up my rebuild now and I wish I would've picked em up before I got into re-assembly. Be sure to inspect the teeth on the inside of the reverse gear and 3rd gear where the keys engage.
I had the same reverse problem and had to replace the gear from being a moron and driving on it.
Old 08-18-2006, 09:44 AM
nvmy2000ss's Avatar
Thanks for the input guys. I will be ordering parts today or monday.
Quick Reply: Will I need more parts for my rebuild?
