What are the best heads to use with a kenne bell on a 346?
Old 08-16-2006, 09:41 PM
blackls6's Avatar
Default What are the best heads to use with a kenne bell on a 346?
Yeah I have a 03 Z06 with lg long tube headers without cats, halltech stinger ssm intake, underdrive pulley, ms3 cam. I am looking into purchasing a kenne bell supercharger and I was wondering what would be the best heads to go with? I have stock cubes(346) and I am not concerned about cost. I really need some opinions asap because I will be purchasing the supercharger coming up shortly. Thank you.
Old 08-16-2006, 10:45 PM
blackls6's Avatar
anyone?
Old 08-16-2006, 10:54 PM
ninetres's Avatar
If money is not a factor, the AFR 225 should work good. They have a 72cc combustion chamber to lower your compression a smidge....and they are AFRs
Old 08-16-2006, 11:09 PM
blackls6's Avatar
Ok thanks. What about the et's? What do you think about those? Also do you think I should get rid of my ms3 cam and go with a blower cam?
Old 08-16-2006, 11:14 PM
ninetres's Avatar
I'm no expert, but I just know you can't go wrong with AFRs. Et makes some bad as heads too. I'm just not as fimilliar with those.
Old 08-16-2006, 11:27 PM
SSilverSSurfer's Avatar
yes you should
Old 08-17-2006, 12:06 AM
blackls6's Avatar
Which blower cam is recomended? Also I am guessing I will have to upgrade my clutch...? Any recomendations on that?
Old 08-17-2006, 12:10 AM
ninetres's Avatar
I'd call Tony Mamo at AFR and order some 225 heads...and have him spec you out a bad *** cam designed EXACTLY for your application.
Old 08-17-2006, 12:11 AM
blackls6's Avatar
Ok I will give him a call...whats his number?
Old 08-17-2006, 12:22 AM
ninetres's Avatar
airflowresearch.com
Find their number....call, ask for Tony Mamo. If he is busy, leave a message and he WILL call you back
Old 08-17-2006, 12:33 AM
or you can send him a pm, i think his name on here is Tony Mamo@AFR
Old 12-12-2006, 05:50 AM
Mr. Sandog's Avatar
What was the outcome on this? What heads did you end up going with?
Quick Reply: What are the best heads to use with a kenne bell on a 346?
