New ls6 intake with 90mm TB Availability
Old 08-17-2006, 03:19 PM
nahasapeemapetalon's Avatar
Default New ls6 intake with 90mm TB Availability
Has anyone purchased this intake kit yet, it was advertised in the new hotrod magazine to include ls6 intake 90mm tb, 36lb/hr injectors and fuel rails for 475 bucks.
Would this 90mm tb alone be worth if for my setup(mods in sig)?
Any guess whats its worth for power?
Is it normal for massive vacuum in the intake or would that signify that the intake setup was more restricitve. Just curious i saw someone post that and i noticed tons of vacumm when trying to plug a hole with a finger haha. Never felt that much b4.
Old 08-17-2006, 03:25 PM
BLAKE 01 WS6's Avatar
i think that setup is for ls2, to match the heads they are selling for $375 ea.
Old 08-17-2006, 03:46 PM
lt1formula2000's Avatar
well as long as you could get a manual/cable throttle body instead of the electric one wouldn't it work.
Old 08-17-2006, 05:16 PM
TVWilkes's Avatar
The manual tb would work,but you have to have L92 heads.
Old 08-17-2006, 09:15 PM
why whats the diff. btwn l92 heads and ls1 heads. As far as i know the intakes bolt up to both ls1/6 heads and truck heads.
Old 08-17-2006, 09:19 PM
spy2520's Avatar
an ls2 intake will bolt to an ls1/6 and vice versa...
Old 08-17-2006, 09:43 PM
yea i thought any lsx head is interchangeable im not sure about the ls7 but everything else should bolt to everything else. Thats a killer deal then, i think a 90mm tb would really open up my car without the maf sensor. are the ls2 intakes comparable to the ls6??
Old 08-17-2006, 10:01 PM
HeapaShifter's Avatar
The L92 is the 6.2L in the new Escalade's and Denali's. If the add you saw was for a L92 setup it won't work on a LS1/LS6. The L92 and LS7 heads each need their own specific intakes.
