Tranny Mount ???
Tranny Mount ???
I snapped my tranny mount in my 00 Z-28. Im trying to get a poly one, but I called energy suspension and they said they dont make one for my car. Where is evryone getting there poly mounts from. One more thing how do I avoid that god awful viration from the poly mount. Thanks.
http://www.ls1speed.com/catagory.cfm...ory=Suspension / Chassis Scroll to the bottom. That's the Energy Suspension one.
I use the Prothane one. I've used both and like the Prothane better. This is the Prothane one. http://www.thunderracing.com/catalog...&vid=3&pcid=92
The same mount works for our '73 Camaro as what will work in my '02. Pretty bad that they don't even know how/where their own products will work! The mount has 3 holes in it, 1 for the center mount (which the LS1 uses) or 2 outside holes for those specific applications.
To help avoid some of the vibration, you can leave the plate that they provide with the mount OUT ... DON'T install that plate!!! Just bolt the mount directly to your tranny, and that's it. For some guys this works, for others, it doesn't. I have/had the poly mount in with my A4, but I put back the factory LS1 mount because I didn't like the vibes it caused. Now I have the poly mount installed with my T56, but again, it's vibrating more than I'd like. Chances are it's my driveshaft CAUSING the vibes, just that the poly mount will actually transmit more of them into the car?
It is livable, if you never drive over 60mph.
You still feel it around town, but it really "shines" over 60 for most people. I believe it is caused by pinion angle or other related area and the mount is transferring it into the car much more than the stock mount did.
I thought it was fine at first as well, until I learned to differentiate between exhaust vibrations and driveline vibrations...then it just became annoying. Especially on the interstate. We don't even take my car there now, and won't until the exhaust is out the back with tips, the OEM mount is back in and my suspension is all done and adjusted properly.
