HELP! Will all my new parts work together??
After I blew my trans a few weeks ago I bought a completely new clutch assembly with the exception of a flywheel. Now im realizing that I might have f*cked everything up. Heres what I got,
1. Spec 3+ clutch Without the lightweight PP
came with pilot bearing , alignment tool and throwout bearing
2. I bought a Ram adjustable master
3. A Ram slave
4. Got stock flywheel resurfaced.
Will these parts all work together or will the flywheel not work with the clutch and the hydraulics not work with the clutch either. PLEASE HELP im going to kill myself thats $900.00 in parts?
3. A Ram slave
The Spec 3+ is supposed to be a great set up, but make sure that you use the spacer, very important. You normally would not need the adjustable master cylinder using the spacer and new flywheel. However depending on how much your old flywheel has been milled you might. Generally a flywheel should be milled < .005".
yeah really dont need the adj. hydrolics but as long as its adjusted right shouldnt hurt anything, I went through the same thing and called SPEC and would recomend a new flywheel but the resurfaced one should work fine as long as you use the spacer
Thankyou both, and this spacer your talking about is it the plate than can be mounted behind the slave cylinder. The piece that comes with the install kit?
