Set or remove stops?
Old 08-19-2006, 02:59 PM
ArrestMeRed99Z28's Avatar
Default Set or remove stops?
I have a 99 Camaro Z28 and I am buying a Pro 5.0 from a friend of mine. My question is does my transmission have internal stops? Do I need to set the stops on the shifter or do I simply remove them? Thanks
Old 08-20-2006, 02:03 PM
t.t.t.
Old 08-20-2006, 03:03 PM
INMY01TA's Avatar
Keep em.
Old 08-20-2006, 03:24 PM
FDKSS's Avatar
Yeah Def set te stops on the shifter or youll be rebuilding your tranny in no time.
Old 08-20-2006, 07:39 PM
thanks, and why don't hurst shifters have built in stops?
Old 08-20-2006, 08:04 PM
Starz T/A 17's Avatar
its not a MUST unless your goin to be shifting like a ****, the B&M's come with them but say you dont have to use them unless your doing ALOT of hard driving. If their there keep up but its not like if you dont have them your tranny will blow up tommorow
Old 08-20-2006, 08:16 PM
GasTiresandOil's Avatar
The t-56 tranny's do have internal stops. I would still set the stops on the shifter as an added bonus, but you can do either.
Old 08-20-2006, 09:16 PM
2000TransAmWS6's Avatar
^i was going to say the same thing
Old 08-24-2006, 12:09 PM
I do like to shift hard at the strip (the Hurst T-Handle makes it way to tempting) so I'll just take the time to set the stops for added insurance, thanks for all the help
Quick Reply: Set or remove stops?
