370 c.i Iron block with vortech ????
Old 08-19-2006, 05:18 PM
NAVY's Avatar
Default 370 c.i Iron block with vortech ????
have any of you guys encountered problems with vortech T.Trim .
sume guys told me the vortech T.Trim its small for 370c.i Iron block ????
thanks
navy
Old 08-21-2006, 06:26 AM
NAVY's Avatar
ttttttttt
Old 08-21-2006, 10:29 AM
MECHAM's Avatar
the T-Trim is a good match with a 370...the drawback is the cooling isnt good enough for a T-Trim. with the basic Vortech kit.
Old 08-21-2006, 11:17 AM
Got Me SOM's Avatar
the aftercooler should be ok, what rmcr is doing is cutting off the nipple on the aftercooler and welding a bigger one, that will help the restriction. They said that aftercooler is good for the YSI up to 15 lbs. I believe its where it necks down that causes restriction and makes more heat not that the aftercooler cant do its job.
