Gears & Axles - Will a 91 camaro rearend fit a 2000 t/a?
stealthair
08-19-2006, 05:50 PM
Buddy of mines gotta a moser 12 bolt for sale outta his 91 maro,, does anybody know if it will bolt up to the 2000 T/a. Thanks.
keliente
08-19-2006, 09:14 PM
I know at least you would need new backing plates, I don't know if the rear end is any narrower or not or if the suspension is set up the same. Depending on whether your car is 3 or 4 channel the abs/tcs might not work either.
SS4Matt
08-20-2006, 01:24 AM
91 is a 3rd gen, and if i remember correctly, the 3rd gens have wider axle/axle tubes....either wider or narrower...either or, i believe they are not the same length,
for some reason it's sticking in my head that the 4th gens are like and inch or something like that narrower then the 3rd gens.
someone else chime in? i know this is not a very 3rd gen oriented site, but maybe someone else will know. just my $0.02
gillbot
08-20-2006, 07:26 AM
3rd gen rears are narrower by 2" overall I believe. If you use one and your stock wheels, they will hit the inner fender well probably. You'd need to use wheels with a 3rd gen backspacing for clearance i'd guess.
Cap'n Pete
08-20-2006, 09:26 AM
3rd-gens would have to be narrower, because the offset of their rims are way shallower than the deep offset of 4th-gen wheels.
SS4Matt
08-20-2006, 10:51 AM
ok so i was 100% wrong but i was on the right track lol
fast377
08-20-2006, 11:04 AM
Yep, but I think it is 3" narrower. I have a 4th gen rear in my 3rd gen. The backing plates are different and there are no provisions for abs stuff. But to answer your question it will work with wheel spacers or different wheels and abs delete and backing plate change.
1999 SS
08-21-2006, 07:42 PM
depending on his price it might be worth buying it then getting the bolt on wheel spacers from eibach or h&r. i think they run from $140 -$200.
91camaross
08-22-2006, 02:02 PM
ya it is 1.5 in narrower on each side but u can get spacers fairly cheap
Smokinstorm
08-22-2006, 10:06 PM
To the thread starter: If you decide not to buy this rearend how about letting me know. A friend of mine is looking for a 12 bolt for a 3rd gen. Thanks.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
