Need Wolfe bar welded in DFW
Old 08-19-2006, 11:15 PM
skipperbisket's Avatar
Default Need Wolfe bar welded in DFW
like the title says. i need to get a wolfe swaybar welded into the TA soon and CHEAP. i have some other things that need welding exhaust and other junk, but the swaybar is the most pertinant at this point.
Old 08-20-2006, 12:12 AM
mitchntx's Avatar
You need a sway bar welded? To what?
If it broke, you need another one. The heat from welding will take all the tensile strength out and it will not perform as it should.
Old 08-20-2006, 12:42 AM
Kewl_Blades's Avatar
you don't weld swaybars...
you need linkage to attach to your TA
Old 08-20-2006, 02:18 AM
red90cobra's Avatar
think he needs the brackets for the the swaybar welded on
Old 08-20-2006, 02:24 AM
sr71bbjr's Avatar
LMFAO AT the first 2 post.....
lindon at 8173200961
Old 08-20-2006, 02:52 AM
Brandon Boomhauer's Avatar
that would be it.
damnit matt, just call up the dr.
or the post above, either can/should set you up.
but first, get a damn motor ready.
Old 08-20-2006, 09:16 AM
V6 Bird's Avatar
Come on now mitch..this is drag racing here buddy.
Old 08-20-2006, 09:17 AM
V6 Bird's Avatar
Which brand of douche do you like better?
Massengil, Summers Eve or store brand?
Old 08-20-2006, 11:17 AM
do huh?
http://www.wolferacecraft.com/detail.aspx?ID=217
you weld this swaybar. how the hell would you connect it to the torque arm?
they are both connected to the rearend. sorry, im really really confused on your post.
Old 08-20-2006, 11:41 AM
FireHawk178's Avatar
Originally Posted by Brandon Boomhauer
do huh?
These are welded to the frame rails..
Old 08-20-2006, 11:46 AM
i know this, i've seen plenty. i was asking the questions to the guy i quoted, trying to figure out what he is talking about.
Old 08-20-2006, 04:20 PM
BP
BP's Avatar
I would call Lindon. I'm guessing he's the guy that used to work for Wolfe?
If it's his old style then it's pretty easy, the newer ones look nicer but take a little more effort. Still though anyone fairly well versed with a welder should be able to install it for you.
Mitch: you'd probably call it more of an anti-roll bar than a swaybar. It's a solid bar that rides inside of a couple of bushings then it has tabs on each end connected to rod ends, connected to tabs welded on the axle housing. It slightly preloads the suspension and won't let the rear suspension twist at all. Kind of like a really thick conventional swaybar but it doesn't affect up and down movement. With a torque arm setup it gives the same advantages as having ladder bars.
Old 08-20-2006, 04:35 PM
AGRV8D's Avatar
does he have a T>A> (trans am)
Old 08-20-2006, 06:30 PM
mitchntx's Avatar
Oh ... it's mash the gas and hang on kinda thing ... no driving required.
Old 08-20-2006, 08:39 PM
do huh?
TA = Trans Am.
Old 08-20-2006, 08:42 PM
The mounts are welded but it still attaches with linkage to the rear.
"Our REAR SWAY BAR is welded between your stock frame rails and is connected to your rear end with spherical rod ends. Unlike most stock sway bars, which are attached with rubber bushings or to the suspension control arms. The attachment with the spherical rod ends ties directly the sway bar into both sides or the rear end housing."
Old 08-20-2006, 09:01 PM
precisely what i was looking for, thanks!
Old 08-20-2006, 09:11 PM
i figured you'd say something like that within 3 replies.
Old 08-20-2006, 09:16 PM
yeah, not driving skill required at all....
Old 08-20-2006, 10:23 PM
mitchntx's Avatar
