What is the best adjustable Fan Switch
Old 08-20-2006, 12:04 PM
White_Ls1's Avatar
Default What is the best adjustable Fan Switch
What is the best adjustable fan switch to go along with a 160 deg thermostat? Thanks -Dave
Old 08-20-2006, 12:14 PM
HavATampa's Avatar
I looked all over for an adjustable fan switch but couldn't find one for our cars. Either it's on or it's off and done manually. You can buy a generic thermo switch and relay and wire it in, big hassle IMO. I finally got HPTuners and adjusted the fan on/off temps that way. Most speed shops will do this for you, but it's not cheap. A local shop that I won't name (sponsor) wanted $100 just to adjust the fan settings. I don't think so.
Old 08-20-2006, 12:31 PM
jmm98LS1's Avatar
Dunno what you mean by adjustable, but SLP makes a manual fan switch that allows you to turn on the low or high fans whenever you want for about $65.
Old 08-20-2006, 01:07 PM
Trunion King
bene's Avatar
Speed shop charged me 75 bucks for reseting my fan settings/deleting codes.
Old 08-20-2006, 01:57 PM
White_Ls1's Avatar
Thanks for the help guys, I will be getting a tune after my stall and LT's, probably have that done at the same time.
Old 08-20-2006, 02:02 PM
HavATampa's Avatar
Adjustable as in you can set the fans to come on and go off at whatever temp you desire without having to remember to flip a switch. Someone makes them for the 3rd gens or older vettes but not for our 4th gens. Here's a universal kit:
http://store.summitracing.com/partde...0&autoview=sku
Old 08-20-2006, 05:06 PM
Pipelayaz's Avatar
Caspers electronics and SLP both sell them. I see more people using SLP's but hey whatever it just turns on your fans. I don't think one is better than the other.
Old 08-20-2006, 06:33 PM
Moderator
jimmyblue's Avatar
Hayden makes a thermostatic fan control, it was about
$40 last I saw it and an ugly box with a bulb-and-tube
type sensor.
Old 08-20-2006, 06:59 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
SLP has a very nice plug and play switch.
Old 08-20-2006, 07:28 PM
HavATampa's Avatar
The keyword of his question was "adjustable" switch. The SLP one is nice but isn't adjustable. The type jimmyblue is talking about has a sensor that is placed in between the fins of the radiator and has a box that you can set to tell what temp you want the fans to turn on.
Old 08-31-2006, 01:45 PM
72LS1Vette's Avatar
SPAL makes a fan controller that is programmable for low and high speed operation. I'm not sure how you would use it to control a low and high speed fan - they might have to be wired to both be on at either speed. The SPAL controller is triggered from the temperature sensor - again I'm not sure how the controller can be integrated into the LS1 engine controls. I'm currently using the SPAL on an older 350 but I intend to try to integrate the controller into my LS1 installation. My controller came from Dewitt's as part of a radiator/fan package for my 72 Vette.
Rick B.
