Stereo & Electronics - Thinking about this...what do you think?
John2005
08-20-2006, 02:16 PM
I am thinking about buying
2 sets of Kicker KS6.2 Component Speakers - http://www.crutchfield.com/S-NxLfVTbYihk/cgi-bin/ProdView.asp?g=410&I=2065KS62&search=Kicker+VENDORID206&SearchDisplay=Kicker
1 set of Kicker SSMB6 6.5 - http://discountave.net/sski61midr2w.html
and a Kicker KX 650.4 Amp - http://reviews.cnet.com/KICKER_KX_650_4_amplifier/4505-6726_7-30785840.html
to finish my system. I am not in a hurry to buy them, probably in about a month I will more than likely buy them unless you have any other suggestions. I am planning on getting some kick panels made for 1 set of the component speakers. I also think I will be getting rid of the 4's in the hatch. I already have 2 x 15" L7's and an Eclipse AVN5435 DVD/Nav Headunit. This should be all I need to complete my system.
Black01M6SS
08-20-2006, 07:02 PM
Looks good if you want to stay with all kicker. You don't really need a 4 channel amp to run the components with if you plan on having 1 set in the door and 1 set in the kicks. You could save some money and get a 2 channel amp and run a set on each channel at 2 ohms instead of getting a 4 channel amp and running each channel at 4 ohms.
John2005
08-20-2006, 08:30 PM
I would like to stay with kicker, but if their are better components to be had at around the same price I really don't care what brand it is. I care about how it sounds in the end.
Black01M6SS
08-20-2006, 11:51 PM
I can't say anything bad about the kicker components because I've never heard them. Kicker is known for making good subs and amps but not so much components. If it were me I would go with some components from a company that was known for making good components. If you want to stay with all Kicker stuff you will probably be happy with them. If the components are anything like the subs they will probably take a beating and get real loud but not have the best sound quality when compaired to brands known for sound quality.
John2005
08-23-2006, 12:23 PM
I ended up buying a 600.4, 1 set of KS 6.5 Components and 1 set of 6.5 SS Mid bass speakers today. Hopefully It will be in by the end of next week and I'll tell you how they sound. Depending on how it is I might end up buying another set of KS 6.5 components
Black01M6SS
08-24-2006, 01:53 AM
Cool, let me know how it sounds. Where are you mounting the midbass speakers? I highly suggest putting them in the doors with a set of components in some custom kicks. The upper range of midbass speakers are directional and it is best if they are kept close to the component set your wanting them to mix with. Also make sure you have crossovers for the mids, not sure if they come with any.
John2005
08-24-2006, 09:41 AM
I'm putting the mid's in the backseat, the components in the front door and later on I wanna put a set of components in some kickpanels
CamaroSS615
08-24-2006, 12:13 PM
Crutchfield is kinda of pricy, you can find the same thing cheaper elese where.
John2005
08-24-2006, 12:38 PM
I didn't buy it from crutch field....I have $350 in it right now...for the amp, SS midbass and 1 set components. I'm 19 and price shop for stuff like crazy.
wickedwarlock
08-24-2006, 02:13 PM
kicker's high end has always done very well for sound quality. There rs5c and rs6c line from 3 years ago has won many awards. Why do you think they were out so long? The SS is a big improvement, I mean night and day difference. I've had mb quartz which at the time I thought were a little better than the RS line, the ss are etirely a different design. I would put them up to any other high end component for sound quality. Yes, they will handle a little more power but none the less, kicker stepped up to the plate to compete in the high end components. They did their homework. I do think they lack on the midbass range, at least in an fbody. If your running any kind of sub, your not going to hear it.
John2005
08-24-2006, 10:06 PM
wickedwarlock you have been the guy whose system I have looked at since I got my 2 x 15" L7's and found out you had them in your car also. I am surprised you didn't remember the couple of pm's I sent you. You have been a big help along the way and another reason I decided to also get kicker components after hearing them in my in 2 of my friends cars(non F-body).
Black01M6SS
08-24-2006, 11:16 PM
Cool, I've always been a Kicker fan but never tried their components because I never heard anything good about them. Back when I was an installer no one around my area really used Kicker mids and highs. The ones that did use them were people that were just wanting to stick with all one brand. I always felt like Kicker focused most of their research on their subs. Times change.
From what I saw the people that stuck with one brand for their whole system were the ones that didn't take the time to research and find out what the best subs, amp, components, ect were for their money. They would just come in knowing that Kicker was a good brand for subs and they would have a whole Kicker system installed. Same with Pioneer, Rockford, ect.
For my money I still think I would go with some lower end MB Quartz or Focals over lower to mid range Kickers. Kicker probably has some really nice top of the line stuff but for the money my bet would be on the brands that have been refining their component systems for years. :engarde:
wickedwarlock
08-28-2006, 12:55 PM
I'm glad your enjoying the audio world. It's addictive. I'm a jl fan and fosgate from the past. I've been using kicker the past two vehciles and have been pleased. I had rs5cs and rs6c in my 2003 dodge quad cab truck. They were not bad, the ss components are such an improvement. But to some, there's 2 other lines they offer aswell. The middle line is nice too, and some people say they are as good as their ss line. It still boils down to choice. I mean, it's your hearing is what counts, not anyone elses. Based on that, buy what you think sounds good to you.
wickedwarlock
08-28-2006, 01:03 PM
The market alwawys changes, kicker waited nearly 10 years to changes that rs line out to the next step. They did some research as I was saying. You are correct, kicker hasn't really defined their product until 2004 (intro of ss line). They have been doing so well for them, as far as that price range. The made a very good product and it placed well for them. I think they decided to step up the notch with the new designed L7 line and the new solo x line they figured they would step up to in the component line.
I agree, speakers really should be your choice, as I have stated in the past, there's really no one good company, everyone's hearing is different (maybe too much bass, we are now all tone def, lol). Seriously, each companies speaker sounds different, so what you may like, I may not and vice versa. Speakers are like buying cars, hehe. There's many choices and we can narrow down what we like. And sometimes, we can't afford what we really want so we take the next best thing to it.
John2005
08-30-2006, 10:55 AM
yep exactly, I wanted the SS Components, but I'm 19 and can't afford that now and didn't want to save up another couple months when I can be enjoying the RS series now. The monsoon speakers are fine to me, except they have no highs and distort easily when turned up which I why I am finally doing what I should have done before I got my subs. The subs drown it out now unless I turn down my bass a bunch and I am hoping it don't drown out the Kicker speakers and if it does I guess I will put another pair of components in. I didn't know much about mmats amps until I got my subs and amp used from a friend and it was a mmats amp and that thing is really under-rated. I had just heard good things about their juggernaut line of subs. I wish you lived closer wicked because I'd like to compare mine to yours when I got done.
wickedwarlock
08-31-2006, 08:09 AM
watch ebay.com There's some good deals there. No way I would spend the msrp retail for those ss. It's over $900 a set, lol.
John2005
08-31-2006, 10:30 AM
I did end up getting it all my stuff off ebay...paid $150 for the kx600.4, paid $120 for the KS 5.2 Components, Paid $130 for the 65.2 Components, and paid $80 for the SS Midbass
So I have $480 in it. Which I would have spent on SS Components only.
rickJames
09-21-2006, 03:32 PM
Did you get all the components installed yet? If so how do you like them?
