Need wheels
Old 08-20-2006, 02:28 PM
LS1ownzYOU's Avatar
Default Need wheels
Well time for new tires and im thinkin about upgrading to some 17s, dont wanna get 18s because im afraid itll sit to high and force me to lower the car which i cant do because of where i live (MASSIVE speed bumps, horrible roads, and giant hills). Looking to get the widest 17" in the back possible w/o rubbing and without modification and same for the front. Any suggestions?
Old 08-20-2006, 05:06 PM
Topless TA's Avatar
18's wont raise the car up anymore than 17's the tire that you choose makes the diffrence. just keep the overall diameter the same and you just get a lower profile tire and more rim but the ride hight stays the same just like 245/50/16 (25.64) and 275/40/17 (25.66)have the same wheel diameter a 285/35/18 will be almost exactly the same at (25.85) just .19 larger side by side you might notice the diffrence, other than that you wont you won't alot of guys run 295/35/18 which is 26.129 and .469 larger about the size of your thumb nail in diamter (no noticible diffrence)
Good luck, here is a link http://www.americanracing.com/techce...Calculator.htm
Old 08-20-2006, 07:32 PM
LS1ownzYOU's Avatar
thanks man, i was thinking some c6 z06 17x9.5s all around, do they have the right offset and backspacing to fit my car? If so whats the best place to pick these up?
Old 08-21-2006, 03:44 PM
Topless TA's Avatar
sharp rims, ebay is usually pretty cheep, check the sponsors on here they are very good as well. I would do a search on the rims on this board or post up and ask about offsetts I know the bird and camaro are diffrent. post up some pics after you get them installed
Old 08-21-2006, 05:21 PM
LS1ownzYOU's Avatar
Fa sho
