chevydad
08-20-2006, 03:40 PM
i'm running a set of 062 heads, with a stock 95 lt1 roller cam. .450/.460 lift.
i know of the problems with springs and lift restrictions. i'm ready to go much bigger with a cam, probably atleast .510-.540 in size. i'm looking for the cheapest and/or easiest way to do it. i was planning on using beehives(which they say increases clearance to .525), then just getting the machine work on the valve guides for the seal to retainer clearance to get me the rest i will need. this will be using 1.5 roller rockers, and i want to keep 1.6's as a future option if desired.
so what i want to know is if there are any new tricks/parts that i may not know of.
and can some of you vortec head users post you cams and spring combos and what was needed to run them if anything
