Stereo & Electronics - Trip odometer resets when cold! Help!
PendragonZ
10-18-2002, 07:09 AM
Hey guys, I've noticed something very odd here.
When the temperature drops to about 32 or below,
my trip odometer decides to reset itself to 0.0.
What's going on here? Anything I can do to fix
this?
-brian
Batmobile/SS
10-18-2002, 11:54 AM
There is a TSB on this issue back for the '99 models. I think the TSB # is 99-08-49-009. Take it to the dealer and it should be covered.
PendragonZ
10-22-2002, 11:43 AM
Looks like it! I'll have to take it in and
get it fixed.
Thanks much!
-brian
PewterZ
10-23-2002, 12:04 AM
Yep the same thing happened to my 99. The ODO would reset and all the gauges peg out at the other position. Exp...the speedo would go to 155 and the TAC would go to 7,000. It is the Gauge cluster going bad.It will start doing it all the time not just when its cold. The dealership will fix it.
O2BQIK
10-26-2002, 06:24 PM
Will they take care of it even if it's not under warranty, since there is a TSB?
Speedfreaks101
10-27-2002, 12:21 AM
Same question, also where can we get a copy of the TSB??
PewterZ
10-28-2002, 07:31 PM
Oh damm....Im not real sure....You can give it a shot...
DROPTAWP
11-02-2002, 09:51 AM
Not likely. The only time that you have repairs done out of warranty at the Dealers expense is under a safety recall. Other than that, your SOL Dude.
A TSB is information that is made available to the Technicians by the Manufacturer. TSB info is not intended for our eyes. Just because GM is aware of a problem and puts it on the TSB list, doesn't mean that it will get repaired at GM's expense outside of your original warranty period.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
