Done with clutch install one problem shifting into second
Old 08-21-2006, 04:59 PM
2KThunder's Avatar
Default Done with clutch install one problem shifting into second
The car shifts into second smooth sometimes but other times it will not enter second at all you have to do all sorts of weird **** like go into neutral and wiggly it and it still hard. We changed the slave and the clutch to LS6. No other problems are apparent. When we did bleed it it doesnt seem like too much air came out. Could this be the cause?
Old 08-21-2006, 06:38 PM
tyrsmkr's Avatar
Old 08-23-2006, 01:07 AM
The PAT WS6's Avatar
get it pressure bled if u can or mity vac it. what clutch did u use and stock flywheel did u resurface it and use a shim?
Old 08-23-2006, 11:29 AM
2KThunder's Avatar
It was the LS6 clutch and new flywheel. We did bleed it but didnt have much luck getting air out. So that is a big possibility. We where using a mityvac.
Quick Reply: Done with clutch install one problem shifting into second
