Florida Members - what oil are u running....
presto_z
08-21-2006, 06:38 PM
just as the title says... i see most people on here prefer mobile1 5w30...... should i do 5w30 or a little heavier???
Caswell
08-21-2006, 07:23 PM
GC 0w30
DirtyBird222
08-21-2006, 07:59 PM
i usually run mobile 1 5w-30 extended performance although i change it every 3k miles, I just run it just in case i forget and because i have 100K+ on the car. It really doesn't matter what you run 0w, 5w, or 10w as long as it's xW-30!
Got Me SOM
08-21-2006, 08:10 PM
I run heavier oil since it so hot and also since i'm blown. 10 w 30 minimum here. I feel the 5 w 30 is just too light and will get by the rings too easy.
Vanzrider
08-21-2006, 10:58 PM
straight up 50
staringback05
08-22-2006, 12:39 AM
5 w30.....
mikespeed95
08-22-2006, 03:16 AM
20w50 lol. im afraid of hurting my motor
Villain281H
08-22-2006, 07:18 AM
Mobil 1 10w 30 in summertime, 5w 30 in fall/winter.
Derek
gator's 99TA
08-22-2006, 07:36 AM
the heavy oil will give you a greater chance to starve bearings of oil.
Country Boy
08-22-2006, 10:07 AM
Explain?
I run a 20w50, but I run it for a reason ;) I used Redline now, but Im going to switch to RP because noone carries RL anywhere.
DirtyBird222
08-22-2006, 02:36 PM
Explain?
grammar > you :jest:
Anyways I never understood why people used 20w-50? When I worked at a lube center, it was always the crazy rednecks in their Exploders, Deathscorts, Taurass, V6 GM Trucks/SUVs, or just random people with like a Camry who wanted that shit. Can someone explain why?
Country Boy
08-22-2006, 02:55 PM
With our climate, if you use a thin oil, in the summer months its like water in the engine and wont cushin anything because our heat will thin it out really bad. All the thin oils are for is when its very cold out, they will flow better on startup. Since we dont get cold, we dont need the thin oils.
I use a 20w50 because when I built my motor, I used a tab of a looser clearence on the bearings because I built it for a 200+ shot. If you build a forged motor with stock clearences and spray the piss out of it with thin oil, youre going to squish the oil from the bearings and risk burning them ultimally killing all the bearings.
The Rookie
08-22-2006, 03:09 PM
RP 10w-30
Caswell
08-22-2006, 03:11 PM
It doesn't take a thin oil to give you good startup properties.
I remember being nervous about the "0" in the GC 0w30, until Patman mentioned that it's actually a very thick 30 weight, almost a 40 weight. Definately thicker than Mobil 1 5w30 I used to put in.
Ericbigmac83
08-22-2006, 03:13 PM
gc 0w30
mikespeed95
08-22-2006, 03:47 PM
i run the thick stuff because 90% of the time my car is on, its banging off the rev limiter in 2-4th gear going around a corner.
i also run about 1 qt extra to help slosh.
presto_z
08-22-2006, 11:07 PM
i would never run 20w 50 in a stoclk ls1.... it says not to right in the owners manual (it really does) but if you built it to run on it then thats a diff. story...... im finally makin the switch to mobile1 5w 30.. thanks for the reply's
Country Boy
08-23-2006, 06:03 AM
I wouldnt either. I tried it and it rattled pretty bad. I did run with 10w30 stock.
Sneakin Deacon
08-24-2006, 06:31 PM
30 weight.
FBodyPerformer
08-24-2006, 08:20 PM
I like i run Mobile1 10w-30. But w/ oil prices I went over to valvoline since i work at a parts store and thats what we carry and I can get it w/ a discount. I was thinking of going to 5w-30 but it would make such a small difference between the 2 Ill just stick w/ 10w-30
We carry Amsoil and i would LOVE to run that stuff, but damn its expensive no matter what!
LT194CamaroZ
08-24-2006, 09:37 PM
GC 0w30 in the LS1 and Mobile 1 Extended 5W30 in the LT1
LSWon00
08-30-2006, 06:41 PM
I was advised by Allan Futral of FUTRAL MOTORSPORTS to run 20w-50 after my cam install since my motor has 80K on it.
