Looking for a pull-out ls1/T56 combo
Looking to pick up a complete LS1 T56 combo to drop into my car. I would also need a wireharness and PCM too. Also would like to get the pedal asy. Looking for a combo with less than 50K miles on it. I am located in Michigan so if you are close to me that would be a plus.
ls1 for sale
I have a 2002 ls1 with T56 engine. Has 150miles. New rings, bearings and gaskets. Port and polished heads. Trans has 65000 miles. With hurst shifter, LUK dual friction button clutch with 2800 lb pressure plate. ECM is a mega squart with custom wiring harness, tuned for stock cam and 24 lb hr injectors. Also if this is a 3rd gen swap your doing, i have pedal accemblies , Halks third gen , wide pipe long tube. and spohn cross member for T56 and motor mount plates. Asking $4000 for motor and transmisson and ECM or $4500 for complete swap. i am located in southern Missouri.
Any questions email me at truckpulling_racingdavid@yahoo.com
I have a T56 and almost new Ram HD clutch/updated hydraulics/Pro5.0 shifter/ all other swap parts that I'm pulling out. Trans was rebuilt about 15,000 miles ago (stock rebuild except for steel shift forks) by ValveGod on this board. Shifts great. I'm in Michigan too. Let me know if you're interested and we can talk $$$
