FAST LSX 90mm
Old 08-21-2006, 10:42 PM
schmidt69's Avatar
Default FAST LSX 90mm
does this just bolt on to a ls1 engine, i already have a LS6 intake with a corvette tb. dont know the mm of that, how do i find out.
thanks
Old 08-21-2006, 10:52 PM
Tainted's Avatar
FAST intakes are a direct reaplcment. you canr euse the vette TB if its 78mm or 90mm the FAST intake has those 2 sizes. the 90/90 set up is for big cube inches or some heads/cam cars
Old 08-21-2006, 11:07 PM
RoastEmSS's Avatar
bolts right on
Old 08-21-2006, 11:14 PM
schmidt69's Avatar
ok i have the following mods, and i guess i have a ported tb with a zo6 maf
GR stage II heads with comp cams 581 224/228
Yella Terra 1.7
Double Comp Springs
moly/titanium everything
Ls6 intake
Whisper Lid
ported TB
should i get the 78mm or the 90mm or should i just keep the LS6 and save for a forged stroker 383 kit
Old 08-21-2006, 11:15 PM
Tainted's Avatar
go 90/90 with your mods
Old 08-23-2006, 10:56 AM
GREATWALLTA's Avatar
you do need to replace the bolts that is holding down the valley cover to shorter ones, because it will be in the way when the intake goes on.
