Rear main leaking... do I need to replaced my new clutch because of it???
O.K. the damn rear main and/or crank plug are now leaking. With that said I think I need to replace the clutch??? Is this true. My Centerforce 12" Dual Friction package only has about 3000 miles on it. The flywheel is no big deal, I will get it resurfaced and balanced, but I'm worried about the clutch disc and PP. Do I need to replace both or just the clutch disc? I'm going to pull the tranny out this Thurs. or Fri. and replace the rear main and crank plug so any help before then would be great!!! Later
You need to inspect it before you order anything. I had a leaking real main seal and none of the oil got onto the clutch. I replaced the rear main seal and the rear cover gasket when I changed the clutch. If oil did get into the clutch, the only thing that might get damaged is the clutch disk, since the material is somewhat porus. I personally don't think oil will destroy the disk. Taking it out and cleaning the friction surfaces with degreaser should do the trick. Any oil that's left will probably burn off due to the heat, or thin out and "seep" out of the pads due to the centriprtal force of the spinning disk.
My two cents
My two cents
Ya the other flywheel's still good. I'll just get the new one turned real quick when I pull it out. So the spare one's still available.
Thanks for the heads up. Hopefully I'll be that lucky. You did bring up a good point though, I should change the rear cover gasket while I'm in there along with the rear main & the crank plug. It's only been leaking for about 2 weeks so hopefully everything's still somewhat clean... hopefully. Thanks again. Later
OK, good news and bad news... I got her torn apart and yes it's leaking (bad news). The rear main's not leaking but the crank plug is and maybe the rear cover gasket (kinda good news... I guess, well at least the rear main's not leaking). As you can see in the pictures it's pretty nasty. The flywheel's hot-spotted a little (so it needs resurfaced), the PP is hot-spotted real bad (needs resurfaced), and the clutch disc doesn't look too bad (but I'm still gonna send it to Centerforce to have them replace the pads, just to be safe). The one question I have is, in the picture, do you guys think the rear cover gasket is leaking? I've inspected it and I can't tell for sure if it is or if it isn't leaking. But by the pattern of the oil spray it kinda looks like the top right of the cover gasket could be leaking. If you have an opinion either way let me know. Thanks!!
Later
Later
My rear main seal went bad with 700 miles on my new textralia clutch. Cars up on jacks and I'll be pullin the trans in a few minutes. I hope nothing got on my new clutch . Wish me luck.
James
James
ЯєŧąяĐ Єl¡m¡иąŧøя ™
James
James
Get a few cans of brake cleaner. I have been there too.
Sounds like a plan. I was leaning towards replacing the cover gasket. So I guess I'll replace while I've got it all apart and the cars on jack stands. I won't get the PP and clutch back until the end of next week anyway. So I've got nothing but time to replace what I need to and get everything cleaned up. I'll do a search on removing and replacing the rear cover. I think I can replace the seal with the cover off. I'll do a search and find out.
Jimmard: Good luck man. I sucks, but what can you do but fix it. I sure as hell ain't paying someone to fix it for me. Let me know how it goes.
