Last minute Advice on Cutout Welding?
Old 08-22-2006, 08:03 PM
02BEAST's Avatar
Question Last minute Advice on Cutout Welding?
Hey guys I'm getting my electric cutout welded on under the rear passenger seat tomorrow any last minute advice or suggestions on a good angle for it to be welded for clearance and should I have the electric plate on it while it gets welded Thanks..
Old 08-22-2006, 09:15 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
put the plate on it until he can size it up so it --[the motor on the elec.part] --is angled up as far as the end will go and still have a bit of room between floorboards and motor for plug/wire not to rub on the floor..... just look at it and you will see what angle it should be...its really simple, but I have seen a couple pics posted that weren't all that good.
Full-Force's Avatar
The most popular way is by welding the cutout inline with the dump pointing out the side of the car.
I dont think it matters if the motor is on it while its being welded.
Old 08-23-2006, 01:06 AM
The PAT WS6's Avatar
good position for a girl riding in ur car lol jus aim it down a lil toward the ground
Old 08-23-2006, 07:12 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Only thing is welding is electric. Food for thought. Send some major electrical pulses like that and you will fry your cut-out motor.
Old 08-23-2006, 09:21 AM
Moderator
jimmyblue's Avatar
You want to fit it up with the whole assembly
but that would be in the way for the actual
work.
I did the fit/shaping of my header-stub piece
before showing up to the shop, myself, for the
location I wanted. That let the mechanic just
chalk and plasma-cut the pipe, and go to town
on the welding. New computer, no pics right now,
but just search up any of my 3 dozen cutout
posts and find a good side view.
Old 08-23-2006, 11:14 AM
jRaskell's Avatar
As long as the motor isn't wired up, there's no physical way for current to flow through it.
Even if it was wired up, it's extremely unlikely the welder is going to cause any damage to it, unless the welder was directly grounded to the motor itself, which no competent welder would think of doing.
Old 08-23-2006, 06:42 PM
NHRAMAN's Avatar
Lightbulb
YEAH----I meant size it up with elec. part on. then remove for ease and go to town..and yes, the angle DOES make a little bit of difference between 'just' fitting and 'fitting real well' ..
