Please help,can i run 5/16 spacer with prostars?
Old 08-22-2006, 09:29 PM
SPRAYED 01's Avatar
Default Please help,can i run 5/16 spacer with prostars?
Im running a 15x10 prostar with a 26x10 et drag. If i run the arp half inch longer studs is okay to run the spacer? If so has anyone run really fast with that setup with no problems?Also do i still need to grind off the bump stop mount? Thanks alot.
Alex
Old 08-22-2006, 09:35 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I have a buddy with a Fox body and he is using a spacer with ARP studs. He's running 6.1x's cutting 1.30 ft's with no problems.
So yes it has been done before and I've never read about anyone running into problems with the bumpstop
Old 08-23-2006, 09:06 AM
LS69TA's Avatar
You should be ok as long as you run the longer studs. What backspacing is the wheel? 7.5? With a 26" tire you shouldn't have to touch the bumpstop.
