t4 inlet and exhaust gaskets
wheres the best place ti get these
seen summit sells the t4 inlet gasket for like 7 bucks but i need the round exhaust...
tried searching kept on getting timed out
Originally Posted by SINISTER
so its good to use like copper seal on the inlet and the exhaust??
anyone else doing this?
bolting eveything up tonight need to know if i need to run out and get ghaskets???
or just a wonderful tube of copper seal rtv sensor safe of course??
Originally Posted by NXRICKY
I have used the rtv o2 safe stuff on the Trucks, manifold to head, turbo to turbo flange, crossovers. Just use a enough to get the job done.
Ricky
Ricky
cool is it better to use the tube stuff or the copper spray??
Closed ex-Sponsor Account
Make sure all areas are clean of dirt grease and oils.
Ricky
Tube rtv, not copper spray. You will need to run a little bead around the points you want to seal.
Ricky
Ricky
allrighty you da man
copper goop for the win!
