I have a little bit of a problem with the turn signals in my 98 TA. Yesterday afternoon, the left turn signal wouldn't blink, it would just freeze in the "on" position. The tailight would light up but just wouldn't blink, however, the front fog light bulb wouldn't even light up. So, I changed the front bulb (actually did both sides because I had two new bulbs). This didn't change the problem.
Then I checked to see if the lights came on when I turned on the headlights. They did! Then I checked to see if the right turn signal was working and now it wasn't. So, at this point I have TWO turn signals that won't blink AND they don't light up for normal driving either.
I checked the fuses and couldn't find a burnt one. Does anybody know which fuse it is? Or what the problem could be? Thanks
CK
Just in case anyone is wondering or has this problem in the future...The right hand turn signal wouldn't work because the NEW bulb I put in was defective. So, one side was just a bad bulb. However, the left hand turn signal turned out to be a bad socket. Spliced in a new socket and problem solved!
CK
