power steering delete
6 Second Club Moderator
I run the Madman rack and skinnies and you don't even notice that power steering is gone.
BTW what's the time frame on your car? It was looking good when I was there.
my pump leaks so i short belt it around town...have not had working steering for a while and it does get annoying....will be fixing the pump soon...but i put up with it for prob 5mths.....with 275's up front as well
would it be fine just taking out the pump? how do you loop the lines or whatever? will it be easy to put the pump back on? im not worried about drive-ability at all i just want to put it back together right if i can.
ok cool, thanks. did they ever make an f-body with a manual rack? i was thinking i could pic one up from a junk yard or something. i hear the madman rack doesnt work for bigger rims/tires. i want to do 17's with 275's up front.
7 Second Club
Originally Posted by kp
Sure you can just take the pump off and loop the lines, but its very hard to steer unless you swap to a real manual rack. I just leave the PS on mine, with a procharger you cant do the short belt and from what I read it only takes a couple HP to drive the pump..
wrong... ... i have no power steering and a procharger.... i took an extra idler pulley i had and machined the stand off hex to accept it... now i have an extra pulley to keep it from rubbing... but it works
KP, manual racks turns 100 times easier than a PS rack that's looped. I could barely turn a looped PS rack.
ty-ty, I'm not wrong, I just meant the short belt alone wont work. I made an idler pulley off the hex on the lower standoff with a P1SC setup three years ago. I would do it on this car but I cant justify 600.00 for 8lbs and lighter then stock steering components on a 3400lb front heavy car..
7 Second Club
i've still got the stock rack and its looped also... im big and strong though
