yank ss3600
yank ss3600
i was wondering at what point tdoes the car start to move forom a dead stop and while just driving around, where do the rpms sit?? am i going to sound like a dick everytime im at a light and it feels like im launching it everytime i dirve? i ask this b/c one of my buddies has a 3500 and his does not move until he is at 3500. he does have an srt4 though so iono if that changes anything
The Yank SS series is one of the tightest line of converters around. I have a heads, cam, longtubes, high-flow cats, etc., car and I'm running the Yank SS3200. I rode in a TCI3500 Camaro and didn't like that at all. My car is very loud and I had the same concern as you. I didn't want to sound like an F15 hitting afterburner everytime I was leaving a stoplight. The SS3200 drives almost like stock. And, with an 800rpm idle, it moves the car in Drive and Reverse, at idle, just like a stock converter. When you hit the loud pedal it explodes. I love it. I'm sure the SS3600 is looser than mine, but I'm also sure it's tighter than any other manufacturer's 35-3600. Yank makes a great converter.
Ed
SS3600 + 3.23 gears here, car moves at 1400-1800rpm's but that is dependant on throttle.
You will be running between 1800-2500rpm's to get around town, unlocked. On the highway you will see around 1500rpm in 4th gear (locked) at about 50mph give or take. I have a video, let me see if I can find it.
Hmm with all that in your sig, I don't see tires? Your car is going to go nowhere
Personally I would do without the gears and see how you like it. Besides its a waste installing them into the stock rear.
I'm considering a stall for a daily driver, that probably wont see the track that often (but I havent been yet so after my first visit I may be going all the time ). At first I was thinking 3000 or less, but everyone seems to say you'll regret it.
BlackHawk - Beautiful car (saw the pics) and helpful vid. Question though. In similar driving (acceleration etc) with stock converter Im mostly under 2k RPMs. I noticed you were usually between 2-3k RPMs. How much does this effect your gas mileage?
Also, doesn't anyone drive a stall without DRs, or is that pretty much a must have? It seems like the life on DRs would be way shorter than streets and you can't rotate.
You can launch a stall at the track on street tires. It just takes a lot of practice. I used to do it all the time. I could cut 1.9 60' on my Bridgestone Potenza RE750's with a SS3600. Excellent street tires IMHO, I highly recommend them. Don't expect to run great times unless you have some sticky tires though. Chances are, you will only be slightly faster than with the stock converter on street tires.
If you want a tighter feel when driving then get a lower stall. From my experience (2 different stalls, Midwest 3400 and Yank SS3600), the car will not feel as fast normal driving with a higher stall. That's just my experience. It could be that my car has not been tuned for the converter. Tuning is highly recommended with a higher stall.
Originally Posted by Roarin_8
Where are you in Melbourne? I'll be back in the area once September is over, I can show you how the converter works.
And for the LS1 engine, you will regret going with a 3000. This is my first converter, and I think I made a great choice. It helps to do your research.
