Instructions on godzilla BOV
mine only has vacuum going to the top port and nothing for the bottom port except a fitting and a couple of inches of hose to atmosphere
http://flowerstechnology.net/images/mechamvac.jpg
I found this for the raptor BOV. I will guess the godzilla is the same, so I will hook it up and see what happens.
http://www.turboneticsinc.com/downlo...ypassValve.pdf
Originally Posted by bowtieman81
Thanks MM
Is there any way to make sure it is not bleeding off boost during operation?
hmmm.....interesting
i hooked my bov with top port vac and bottom port boost. and it sounds different from a wot run. everything else seems the same...
car doesnt hold requested boost to redline...nothing new there..
i was hoping this might of solved something....o well...at least it sounds different. ie..i can hear the bov more from a wot run.
