Dumbest question, or Hardest??
Old 08-24-2006, 07:53 AM
AeroKing's Avatar
Default Dumbest question, or Hardest??
Well, What makes a Supercharger/ or Turbo whine (at idle)??
Is it ?
-Undergreased bearings
-Overgreased Bearings
-Lack of oil
-Too much oil
-Blower Belt
Or what?
Old 08-24-2006, 08:00 AM
navymitch12's Avatar
its because of the sounds that the turbine makes....nothing is wrong with it
Old 08-24-2006, 09:25 AM
smokinHawk's Avatar
on the supercharger youll also hear the whine of the gears, its how there cut.
Old 08-24-2006, 09:38 AM
AeroKing's Avatar
i know the woosh sound comes from the impeller sucking air, but the high pitched whine i guess comes from gears when the car isnt making boost?
Old 08-24-2006, 01:45 PM
MIGHTYMOUSE's Avatar
turbos dont make noise at idle
s/c you hear noise from the step up gear ratio
Old 08-24-2006, 02:07 PM
ls1charged's Avatar
yeah i dont recall hearing a whining noise on a turbo, its a little different, its more like a sound a jet makes when its taking off.
Old 08-24-2006, 02:59 PM
DeltaT's Avatar
As said most SC whine is from gears, but I also get some from my Mondo bypass - it's more of a whistle at idle. It may be due to how I have it set up.
Jim
Old 08-24-2006, 03:07 PM
TransAm6383's Avatar
theres little elfs in there and the sound you hear is them sucking in air to blow into your engine...theres 3 or 4 i think...
Old 08-24-2006, 03:59 PM
LS1TECH Sponsor
DrTurbo's Avatar
If you hear the turbo at idle...turn the car off , its time for a rebuild...
Quick Reply: Dumbest question, or Hardest??
