shell gas and service engine light
Old 08-24-2006, 12:53 PM
01z
01z's Avatar
Default shell gas and service engine light
everytime i get gas there it makes my service engine light come on and i was wondering if that happens to anyone else. i have no clue why, i guess v power just plain sucks *****
Old 08-24-2006, 01:00 PM
SEB
SEB's Avatar
I had the same thing happen to me. As soon as I put the Exxon in it. My ses light was gone. Your not alone.
V-POWER my A$$!
Old 08-24-2006, 01:03 PM
Stang's Bane's Avatar
I have just the opposite effect. My car gets 1-2 mpg better with V-power than anything else. Power levels are the same.
Old 08-24-2006, 01:44 PM
BLACKZ02's Avatar
That's why I fill up at RaceTrack.
Old 08-24-2006, 01:47 PM
dubs6's Avatar
Check to make sure you gas nozzle is screwed on tightly. You could be throwing an evap code if you didnt turn it enough or screw it on properly.
As far as shell on I have run 11's on their gas.
Old 08-24-2006, 03:59 PM
Saad06's Avatar
my car and I love V-power. it contains 10% ethanol, and i too get better gas mileage and same power level. no SES light
Old 08-24-2006, 05:22 PM
K.T.'s Avatar
I always loved Diamond Shamrocks 93. That **** ROCKED on the dope.
Old 08-24-2006, 05:58 PM
dubs6's Avatar
My mom works for an oil exporation group and she said shamrock is the gas that other's did not want.
Old 08-24-2006, 06:43 PM
Reject's Avatar
shell took care of my 5 mpg problem
Old 08-24-2006, 07:53 PM
Doomsday's Avatar
Made my SES light go away more often compared to Chevron.
Old 08-24-2006, 08:34 PM
FatZ28's Avatar
Yeah I have never had a problem with shell and have been using it for awhile. Does the station you get the gas at really old? They might have old tanks.
Old 08-24-2006, 09:18 PM
Were you on spencer today at about 5?
Old 08-24-2006, 09:51 PM
Moderator
jimmyblue's Avatar
V-power is oxygenated fuel and if you were tuned up
tight on 93 octane straight gasoline you could run into
some lean / ping conditions. Let alone if your setup
had some pre-existing lean error. My car pinged badly
and was down on power the one and only time I put
that save-the-planet ****-water in my tank.
Old 08-25-2006, 12:01 AM
1gen's Avatar
my **** runs better and gets better gas on vpower
Old 08-25-2006, 12:35 AM
dubs6's Avatar
only in Florida
Old 08-25-2006, 01:40 AM
thebatman411's Avatar
I normally don't put diamond shamrock gas, but the price I saw on 93 octane was too tempting (2.87). Anyway, it'll be the last time I put that gas in my car. I was having problems with my car all day. First thing in the morning I'm filling up tank with chevron. Chevron has always done my car good.
Old 08-25-2006, 10:03 AM
MAXIMO's Avatar
I use them both no problem. I always run 93 in mmy car and usually use exxon but sometime when im low on fuel ill stop at a shell nothing less.
Old 08-25-2006, 11:34 AM
A-Dub's Avatar
Diamond Shamrock gets their gas from Valero.....definitely not leftovers. Valero is the largest or next to the largest gasoline refiner. There are no leftovers when it comes to gas. Regardless of the refinery, it all goes into a pipeline. EVERYONE puts gas into it. So if Exxon put 1.5million gallons in, they can take 1.5million gallons out, but there is no way of knowing it was the same 1.5million gallons that they put in since all the other refiners are dumping in there as well. The difference comes between the pipeline and pump... thats when the different retailers add their additives such as Vpower and Techron.
Old 08-25-2006, 11:53 AM
chupr0kabra's Avatar
A lot of it has to do with the particular station, more than the brand. All it takes is a little crap in the tanks at the station and you'll have all kinds of weird problems. The Conoco near my house consistantly gives my Camaro and my wife's Equinox fits. Every other Conoco causes no problems.
-Mike
Old 08-25-2006, 12:32 PM
I work in oil refineries and I can honestly tell you that trucks from every company fill up at every other refinery. The only difference is the additives, and those are put in after the fact.
