Suspension & Brakes - Baer Bear claw GT+ kit on Stock 17" WS6 wheels
GREATWALLTA
08-24-2006, 05:34 PM
Hey you guys, I just bought a new Baer GT+ brake kit for the front of my 2002 WS6 Trans Am. So far all the pictures and threads I have read had the kit with after market wheels set up. I have the Collector's Edition Trans Am with the black 17 x 9 wheels. I was just wondering will the kit fit behind of the stock wheel or not? I can even put up with a little bit of modification if needed to have those brakes too. But I need to know if its even possible with the stock wheels period. Any comment, ideas, or pictures will be greatly appreciated. Thanks alot.
GREATWALLTA
08-24-2006, 08:37 PM
well anybody? any kind information at all well be a great help...
GREATWALLTA
08-25-2006, 11:54 AM
Bump. Anybody At All?
GREATWALLTA
08-25-2006, 05:27 PM
bump!
jpat1023
08-25-2006, 06:32 PM
haha well since nobody seems to know, I'll take a stab at it and say that I think they will fit. Whats the point of making a product for a car if it doesn't fit?
11 Bravo
08-25-2006, 08:39 PM
I'm sure they will fit. I have Baer Extreme 6 pistons and I have to run an 18 inch wheel. Your calipers are a good bit smaller. As long as you don't have 14 inch rotors you should be good.
GREATWALLTA
08-25-2006, 10:44 PM
I am getting the 13.1 inch rotors, they are suppose to be a bit thicker than the stock ones too. The calibers are same size as the vette ones. so I hope they will fit. I really want them on my car.
11 Bravo
08-26-2006, 07:20 AM
Baer has a fitment template on their website that will show you if they fit or not.
01 Red WS6
08-26-2006, 03:03 PM
They should fit. If they fit with TT2s then they should fit with stock 17s
1QUIKWS6
08-28-2006, 10:23 AM
Same kit did NOT fit my 17" TTII's. Ended up having to grind off the front leading edge of the caliper fins so as to not interfere with inner wheel bump-out directly behind the spokes.
Also had to grind the huge welds that run around the front edge of the lower control arm nose as they actually hit the inner braking surface of the Eradispeed 2-pc rotors.
I have no experience with the fitment to the standard factory WS6 wheels - but as mentioned there is a fitment guide template available from Baer. I decided not to go to the trouble when I purchased my kit and went based on the salesman stating that they would fit with no interference.
Sure wasn't big on grinding on $1600 calipers - but at that point I had already cut off the ears of my stock spindles to allow for the Baer caliper brackets and wasn't about to turn back...
-Jay-
DVST8OR
08-28-2006, 03:16 PM
From what I have been told, they will fit stock 17" wheels just so long as the wheel weights are on the outside of the wheel. But I would say your best bet is to do what others have said and use the template on the Baer website.
GREATWALLTA
08-28-2006, 05:22 PM
Thanks alot guys, They will arrive tommorow. I guess there is only one way to find out. I want to put these on my car regurdless the outcome. But so far I feel a bit better about doing this, since nobody has yet to come in and said that it is impossible. I guess that is a good thing. Some say it fits, some say not. I will be finding it out soon and I will post the pictures however the outcome is. Thanks you guys.
1QUIKWS6
08-28-2006, 06:31 PM
Here's some closeups with the GT+ kit and the TTII's. As you can see, the face of the caliper just clears behind the spokes - after I ground down the cooling fins I have around 1/8" clearance between caliper and the bulge in the wheel rim directly behind the spokes. Never had a problem with any interferance after I took care of the slight modifications described in my earlier post...
http://i27.photobucket.com/albums/c192/1QuikWS6/BaerCaliperClose.jpg
http://i27.photobucket.com/albums/c192/1QuikWS6/TTIIWheel.jpg
01 Red WS6
08-28-2006, 08:06 PM
I remembered seeing your pictures but I thought there was another person that was able to get them to fit with no modification. Maybe not though. I do know that TT2s don't allow as much clearance as the factory wheels.
GREATWALLTA
08-29-2006, 09:59 AM
wow that looks damn good! Was it worth the upgrade performance wise? How much is it better than the stock units, and by the way does it sqeak any?
