List of bore/stroke combinations
So after the 6.0 bore / 4.8 stroke thread I was thinking about all the combinations for Gen III/IV engines. There a quite a few combinations, and many are pretty good, but some are just odd.
If this is not advanced enough, feel free to move.
3.779" bore combinations
3.268" stroke: 293.2ci or 4.8L (Stock 4.8L combo)
3.622" stroke: 325.0ci or 5.3L (Stock 5.3L combo)
3.819" stroke: 342.7ci or 5.6L
4.000" stroke: 358.9ci or 5.9L
4.125" stroke: 370.1ci or 6.1L
3.898" bore combinations
3.268" stroke: 312.0ci or 5.1L
3.622" stroke: 345.8ci or 5.7L (Stock 5.7L combo)
3.819" stroke: 364.8ci or 6.0L
4.000" stroke: 381.9ci or 6.3L
4.125" stroke: 393.8ci or 6.4L
4.000" bore combinations
3.268" stroke: 328.5ci or 5.4L
3.622" stroke: 364.1ci or 6.0L (Stock 6.0L combo)
3.819" stroke: 383.9ci or 6.3L
4.000" stroke: 402.1ci or 6.6L
4.125" stroke: 414.7ci or 6.8L
4.065" bore combinations
3.268" stroke: 339.3ci or 5.6L
3.622" stroke: 376.1ci or 6.2L (Stock 6.2L combo)
3.819" stroke: 396.5ci or 6.5L
4.000" stroke: 415.3ci or 6.8L
4.125" stroke: 428.3ci or 7.0L
4.125" bore combinations
3.268" stroke: 349.4ci or 5.7L
3.622" stroke: 387.2ci or 6.3L
3.819" stroke: 408.3ci or 6.7L
4.000" stroke: 427.6ci or 7.0L (Stock 7.0L combo)
4.125" stroke: 441.1ci or 7.2L
The following users liked this post:
John Newman (03-01-2020)
How about 470.1 CI?
If that new cast iron block GM is working on becomes a reality, it will almost certainly be capable of a 4.200 bore (the aftermarket sbc are and they share the same bore spacing). Combine that with the 4.250 stroke crank and there you have it.
Here is your list with some more combinations...
3.625” stroke: 325.2ci or 5.3L
3.900” stroke: 349.9ci or 5.7L
4.100” stroke: 367.9ci or 6.0L
3.625” stroke: 346.1ci or 5.7L
3.900” stroke: 372.3ci or 6.1L
4.100” stroke: 391.4ci or 6.4L
4.125" stroke: 393.8ci or 6.5L
3.905" bore combinations
3.268" stroke: 313.1ci or 5.1L
3.622" stroke: 347.0ci or 5.7L
3.625” stroke: 347.3ci or 5.7L
3.819" stroke: 365.9ci or 6.0L
3.900” stroke: 373.6ci or 6.1L
4.000" stroke: 383.3ci or 6.3L
4.100” stroke: 392.8ci or 6.4L
4.125" stroke: 395.2ci or 6.5L
3.625” stroke: 364.4ci or 6.0L
4.000" stroke: 392.1ci or 6.4L
4.100” stroke: 412.2ci or 6.8L
4.030" bore combinations
3.268" stroke: 333.4ci or 5.5L
3.622" stroke: 369.6ci or 6.1L
3.625” stroke: 369.9ci or 6.1L
3.819" stroke: 389.7ci or 6.4L
3.900” stroke: 398.0ci or 6.5L
4.000" stroke: 408.2ci or 6.7L
4.100” stroke: 418.4ci or 6.9L
4.125" stroke: 420.9ci or 6.9L
4.060" bore combinations
3.268" stroke: 338.5ci or 5.6L
3.622" stroke: 375.1ci or 6.2L
3.625” stroke: 375.4ci or 6.2L
3.819" stroke: 395.5ci or 6.5L
3.900” stroke: 403.9ci or 6.6L
4.000" stroke: 414.2ci or 6.8L
4.100” stroke: 424.6ci or 7.0L
4.125" stroke: 427.2ci or 7.0L
3.625” stroke: 376.4ci or 5.3L
3.900” stroke: 404.9ci or 6.6L
4.100” stroke: 425.7ci or 7.0L
4.100" bore combinations
3.268" stroke: 345.1ci or 5.7L
3.622" stroke: 382.5ci or 6.3L
3.625” stroke: 382.9ci or 6.3L
3.819" stroke: 403.4ci or 6.6L
3.900” stroke: 411.9ci or 6.8L
4.000" stroke: 422.4ci or 6.9L
4.100” stroke: 433.0ci or 7.1L
4.125" stroke: 435.7ci or 7.1L
3.625” stroke: 387.6ci or 6.4L
3.900” stroke: 417.0ci or 6.8L
4.100” stroke: 438.3ci or 7.2L
Originally Posted by DONAIMIAN
you forget that you can get an LS1 sleeved to 4.2 bore. Also I belive the C5-R block can be finished at 4.160.
Originally Posted by SStrokerAce
Why don't you just list all the possible cranks out there and the bore sizes of the blocks and TEACH someone the dam formula...
bore x bore x stroke x cylinders x .7854 = cubes
pie(3.14) x radius(1/2 bore) x radius(1/2 bore)= area of circle
area of circle x stroke x number of cylinders = displacement (all in inches)
(i.e. 3.14*2.015*2.015*3.48*8=355)
Originally Posted by BOWTIE
Thats easier than the one i have always used (except I would never remember the .7854 number). I have always just used the high school geometry formula:
.7854 is PI/4, so you don't have to divide the bore by 2.
Now .7854 are the four numbers going clockwise from the upper left corner of the keypad on calculators and computers, so you don't have to remember the number or use the PI key or remember PI.
My memory is so short, so I need all the help I can get. I can remember bore, stroke and number of cylinders....usually.
