SSRA w/ tranny cooler?
Old 08-25-2006, 02:51 PM
1fastz28nx's Avatar
Default SSRA w/ tranny cooler?
Can anyone tell me if the SSRA will fit with a tranny cooler installed? Just wondering before I buy one. Thanks.
Old 08-25-2006, 02:55 PM
Moderator
jimmyblue's Avatar
Dunno about SSRA but SLP CAI plus a Hayden 24000
cooler was basically covering up half of my radiator.
I'd relocate the trans cooler if you go with the ducted
cold air pieces.
Old 08-25-2006, 02:58 PM
2001NBMZ28's Avatar
If it's already installed might need to move it over a little or remount it dope style, horizontally. Did mine that way a few years ago and it's been fine.
Old 08-26-2006, 06:19 PM
FireSilverLullaby's Avatar
Where else can you mount the tranny cooler. Like horizontley under the car or soemthing?
Old 08-26-2006, 09:55 PM
Tainted's Avatar
mount it off to the side neart the splash guades face donw towards the road
Old 08-27-2006, 01:53 AM
Jake the SSnake's Avatar
I put mine between the radiator and the ac condenser,its a tight fit but it works good.
Old 08-27-2006, 02:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I have seen the TC mounted like the intercoolers for the ATI procharger setup's are....scoop an all. Not a bad plan.
Old 08-27-2006, 09:53 PM
c0ncEpT's Avatar
My friend Has his tranny cooler mounted right behind his passenger turn signal and slightily down so the air from the unused slot unter the turn signal flows right in (Trans Am by the way)
Old 08-29-2006, 08:56 AM
1fastz28nx's Avatar
Can someone post up pics of the SSRA? I'd like to see some looking up in front of the radiator. I know it will be a pain to get to it, but if anyone has them I would appreciate them.
This is the tranny cooler I have:
Extra Heavy Duty Transmission Cooler
26,000 GVW
10'' x 20'' x 3/4''
8 Passes
Quick Reply: SSRA w/ tranny cooler?
