Any problems with a MBC?
My Turbosmart MBC works just fine. Nothing fancy... No settings, sits in the engine compartment, the little dial goes left/right, boost is ALWAYS steady, and the dial can be locked from tampering/movment with a simple alan-head... Eboost2 is for ballers.
I'd only do Eboost if I was planning on switching between two tunes often, pump/race fuel. My boost is always max... If I want less boost I use less throttle. JMO.
Originally Posted by TransAm6383
Eboost2 sucks. Its so hard to figure out. get a dual stage boost controller..you can flip between 2 preset boost levels with the flip of a switch.
