ACDelco Iridium Spark Plugs
Old 08-27-2006, 12:43 PM
98BlkFormula's Avatar
Default ACDelco Iridium Spark Plugs
Im changing the plugs on my car and i need to know what to gap them at. The ony thing i have done to my car is the K&N air filter and i have some headers that i bought but havent put them on and also i have a SLP Lid on the way. Sould i gap the plugs at .60 or .55?
Old 08-27-2006, 01:08 PM
Anyone?
Old 08-27-2006, 01:17 PM
WhiteRhino's Avatar
Mine are gapped at .055. Just do what stock calls for and you should be fine.
Old 08-27-2006, 01:32 PM
GMTECH4's Avatar
you don't gap those plugs you will miss up the iridium tip look how thin it is
Old 08-27-2006, 03:27 PM
WhiteRhino's Avatar
The iridiums dont come pregapped. It says right on the box to set to recommended application gap. If you can't set the gap without messing up the plug, then imo you shouldn't be changing your own plugs. Even preset plugs are usually off. I never put a plug in without checking it.
I just did my wifes Trailblazer. They're suppose to be at .043. Not one of the new plugs were the same. They varied from .038 to .055. These were ac delco 41-965 platinum's.
Old 08-27-2006, 05:15 PM
on the back of the box it says "SET GAP PER VEHICLE SPECIFICATION"
and no where on the box it says pergapped.
Old 08-27-2006, 07:48 PM
Starz T/A 17's Avatar
If you do it right you wont screw it up but alot of people scrap the hell outa the tip and defent the whole purpose of gettin the irridium plugs
Old 08-27-2006, 10:59 PM
GMTECH4's Avatar
It's your money and your car i work at a gm-dealer and there is a technical service bulltin #03-06-04-060. this only applys to the iridium plugs not platinum.
Old 08-28-2006, 12:05 AM
Asmodeus's Avatar
my denso iridiums came pre-gapped, my tech said don't gap them.. even had a nice plastic ring around the electrode side to prevent damage and gap changes. I just put them in, no problems.
here's the link from their site:
http://densoiridium.com/installationguide.php
Old 08-28-2006, 12:02 PM
WhiteRhino's Avatar
Do they at least check the gaps. More than likely they just throw them in. This is the reason I never take my car to a dealer. No offense, it just bothers me when someone says I work at a dealer. Some of the dumbest mechanics I know work at dealerships.
Asmodeus, It doesn't say not to gap them. What that says it what I already said. If you don't know how to gap a plug imo you shouldn't be changing them. So at the very least they should be checked.
Installation Guide
IRIDIUM POWER™ GAPPING TIPS
Before attempting to gap any DENSO Iridium Power spark plug, please review the specification chart in the front of this catalog to verify the factory-preset gap. In most cases your Iridium Power plugs do not need to be gapped. Even with small variations in the factory set gap the ultra-efficient firing power design will compensate for those small variations.
""""""Should you decide to re-gap your Iridium Power plug, use extreme caution as improper gapping may damage or destroy the Iridium center electrode or porcelain center.""""""
To increase the gap size:
• Step 1: Use needle nose pliers or spark plug gapping tool to bend the ground strap up to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN.
• Step 2: Re-check the gap with a calibrated gapping tool.
To decrease the gap size:
• Step 1: Use the same method as above, however bend the ground strap down to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN.
• Step 2: Re-check the gap with a calibrated gapping tool. WARNING: Failure to follow these directions may permanently damage the spark plug. Note: Never use a round gapping tool to check the gap or to increase or decrease the gap setting.
Old 08-28-2006, 04:10 PM
Asmodeus's Avatar
I never said Denso says don't gap them. Reread my post. Or, I got an idea. How about this. I won't change my plugs until I "learn how to gap them" if you don't post anymore until you learn some reading comprehension, ok?
Old 08-28-2006, 04:15 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
simple..just check the gap.... .55-.60 is fine..they do come pre-gapped..checked mine and they were all .55/.57.....good enough unless you are racing or ****.............
Old 08-28-2006, 08:52 PM
WhiteRhino's Avatar
I never said you said either. Your exact words were; "my denso iridiums came pre-gapped, my tech said don't gap them". You took me saying "you" as if I was refering to "you" when it was a generalised statement. Refering to anyone that isn't sure how to gap a plug. Get over it, I wasn't singling or trying to bash you.
So maybe you should learn how to comprehend as well. Untill then lighten up. If you need you can send your plugs to me and I'll check/gap them for you.
Bottom line, like Nhraman said as well. The gap should be at least checked. Being off a couple thousandths doesn't make a difference.
Old 08-28-2006, 09:32 PM
Flawless02SS's Avatar
I was always told not to gap them too. I just put mine in and no problems. Runs like a top!
Old 08-29-2006, 11:40 AM
DoubleTapDrew's Avatar
What P/N Iridiums are you guys using? I looked up the OE plugs (I work at a GM dealer too) and it gave me 41-985 iridium. On the description it says "(DO NOT CHANGE SPARK PLUG GAP FROM .040")(ACDelco #41-985)(IRIDIUM)" and refers to a service bulletin. I checked the gap last night and they are all .038"-.040". Do I need to spread them to .055" or are these not the right plugs to use?
Old 08-29-2006, 12:00 PM
WhiteRhino's Avatar
My car seemed to run rough when I left them at .040. I pulled them out and put them to .055. I'm not saying you should do it as well. Try them at .040. If all is fine then don't worry. My car is far from stock and I've had to move the gap for different style plugs. You would think .040 would be better for spark, but my car likes a wider gap for some reason. The reason it says not to deviate is probably because people mess up the iridium not doing it properly. I bought mine a long time ago and I remember it saying something to the effect to rec. app. gap. You can also find a different plug part number, same style plug with a gap closer to what you want. As long as it's for an Lsx application.
Old 08-29-2006, 12:07 PM
Ok. This is my first LS1 and if the plugs are as much of a PITA to change as my 5.3L truck's then I'd like to get it right the first time!
The car is mostly stock right now, just a lid and cat-back (LTs and ORY coming soon) but it has 82K mi. and I'm sure they've never been changed.
Old 08-29-2006, 01:39 PM
Asmodeus's Avatar
Prob go with the ngk's then, I spent almost 100 bucks for my denso iridiums
Old 08-29-2006, 06:26 PM
Yikes! The Delco Iridiums set me back $38.
Old 05-17-2010, 08:45 PM
getcha 01's Avatar
Default how?
How did u get iridiums for $38?....You had to get them used or u dont have iridiums. They run $10 a piece most everywhere, sumtimes 12, sometimes 9. I paid $86 with tax 2 years ago.
Quick Reply: ACDelco Iridium Spark Plugs
