Stereo & Electronics - Why is my system not working?
emj2006
08-27-2006, 03:15 PM
For some reason, my system only works for a small amount of time(like 10 seconds) and then it stops pounding! Am I not getting enough power or something? Any fuses I need to check or something? Please help cause it is driving me nuts!
Duffster
08-27-2006, 03:30 PM
Alright, I'm going to GUESS since there are no details. You've mixed Monsoon componants with aftermarket componants (ie monsoon headunit with aftermarket speakers) and it's not happy.
97MysticZ
08-27-2006, 03:54 PM
Check to see if the fuse on the power cable is loose. I got a cheap one from walmart and it was wiggling around and my shit would quit working. I bought a good Rockford Fosgate AGU fuse holder and fuse from best buy and replaced the old shitty one. Works like a dream now.
carvelo
08-28-2006, 11:22 PM
Ditto that ^^^ I am struggling with the same problem. I even noticed when I would turn a corner, it would sometimes come on for a second.
The other - and more common issue - is that your ground is not sufficient for your amp. Check the ground to make sure it is secure and make sure that your ground wire is short enough. It shouldn't be much more than 3 feet in length.
98TA Bandit
08-28-2006, 11:30 PM
IF you have added new speakers and grounded your amp on the nut holding down the seat belt return make sure no metal from the speaker is touching that same piece of grounded metal. Also like stated above check ground and make sure you have got the ground location sanded clean as possible, no rust or paint. Good luck man!!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
