Ls7 Clutch Users Come Inside....
Old 08-28-2006, 10:16 AM
flippin's Avatar
Default Ls7 Clutch Users Come Inside....
I was just wondering if someone might be able to let me know exactly what i need for the ls7 clutch install, and i will be updating the hydraulics also. What will i need for that? Slave? Master? Drill mod? Ls2 flywheel. Thanks i dont want to forget anything when i order the parts.
Old 08-28-2006, 10:55 AM
warp10's Avatar
I think you have most of the stuff there.
Master, Slave, LS2 flywheel.
Drill mod is required.
I would just add new flywheel bolts, DexIII (4 LTRS) and Dot 4 brake fluid to refill the hydraulics.
Old 08-28-2006, 04:05 PM
SS#2906's Avatar
Depending on where you buy your parts from, make sure you pick up the throw out bearing. Most slaves come with it, Fred Beans Parts sales it separate with their kit. FredBeansParts.com, part number LS7clutchkit.
