Generation IV Internal Engine - Trak recipie??
View Full Version : Trak recipie??
Z06 Steve
08-28-2006, 02:57 PM
I'm looking for a recipie for my 07 C6 stock block LS2.plan on using the trak cam but what heads,cc,head gasket,ect will make a killer combo?
Z06 Steve
08-30-2006, 08:09 PM
the best cam to date and no feed back on a combo???
Patrick G
08-30-2006, 09:30 PM
Depends on how much power you want to make. Mr Z51 made over 450 rwhp using the TR TRak cam on his stock headed LS2. Headers and ported LS2 intake were other key components. If you want more power than that, then you'll need to stip up to some high flow aftermarket cylinder heads. All the ones in the $2000+ price range will give you another 40+ rwhp over your 243 heads with the proper chamber and port size.
Z06 Steve
09-03-2006, 09:01 PM
thanks....I would like to go with a TFS 215 because of the extra clearence.I would like 11:1 comp.So if the heads are 64cc i'll need 20 milled off and what head gaskets would give the best quench cometic 40's ?.would there be enough piston to valve space?so if anyone has something similar it would be of great help to go with a proven combo.I wonder how the TFS stage 3 cam would dyno vs. the Trak too.
caindo
09-05-2006, 06:16 PM
arizona power and sound
