LS6 intake or not?!?
Here is the situation. I bought this car off tech last March. The gentleman said it had an LS6 intake and camshaft (with springs). I do not think this is an LS6 intake since it does not look like others I have seen. The number above the firing order on the driver side is stamped: 12561184. Below are two pictures for reference. I !EGR and !AIR last winter.
Any insight is appreciated
Andy
Andy
Originally Posted by Gearhead1
I did a search and it said 12561184 was an '01 up F-Body LS6 intake. I don't know why it would have EGR provisions, though. Were the SLP LS6's w/EGR a modified factory LS6 intake??
Andy
Originally Posted by bene
yeah looks like you've got SLP LS6 intake w/ egr provision.
Thanks for the replies.
Andy
Originally Posted by jlrz28
What did the egr tube look like when you cut it off? The SLP looks like this, i guess a flare fitting?
Here is my intake with EGR:
I did not cut anthing off. It was one bolt holding it into the intake. The SLP one appears to have recessed areas where the EGR pipe bolts to. If you look at my first pictures, my intakes top is flat with no recesses.
Andy
