Forced Induction - Cant stop the smoking
bowtieman81
08-29-2006, 09:50 PM
Well, I tried several things today in an effort to stop my TTi kit from smoking. I put a .080" restrictor in the feed line, no difference that I could tell. Pulled the PCV hoses off the valve cover and valley cover to make sure there was no crankcase pressure, no change in smoking. Also pulled my return hose off the oil pan and had my buddy start the car. Got about a quart out the return hose, but the thing still smoked. It seemed to smoke a bit less with this procedure, but still way more than it should.
If anybody else has any suggestions I am all ears. If it is the turbo, then I am likely done and putting the thing up for sale.
frcefed98
08-29-2006, 09:59 PM
If it did push some oil through the turbo into the DP due to too much oil volume, then it will take some time for the oil to burn out of the exhaust(DP back)
When mine did this, it smoked a lot. I had to clean out the DP all the way to after the cat with some carb cleaner to clean most of the oil out of the pipes.
IF the turbo does need a rebuild i'm sure it wont be too bad on the wallet to have it done. You've come this far, don't give up:D Its all part of this fun FI game:bang:
J:D
StoleIt
08-29-2006, 10:12 PM
Yea with the amount of crap you have gone through...you just HAVE to finish it.
ninetres
08-29-2006, 10:13 PM
http://www.speed.co.jp/asf/pic/niccorette.jpg
Jk man. Good luck.
Ryan K
08-29-2006, 10:49 PM
I second the "don't give up" motion, trust me it'll be worth it!
bowtieman81
08-30-2006, 07:51 AM
I still hate the idea of a restrictor, especially since you other TTi guys dont use one.
Do you think I should try a scavenge pump, or just take it off and send it to Jose?
MIGHTYMOUSE
08-30-2006, 08:11 AM
you could try a .065 restrictor but i wouldnt go lower than that
my turbo is too low, so i apply a vacuum to the crankcase to help pull the oil out of the turbo and it has worked flawlessly
remove and replace the pcv system with a set of vent hoses to the pipe btwn the air filter and turbo, then run another line between the intake somewhere behind the throttlebody, and the crankcase. you will need an oil separator here to keep it from sucking oil into the intake, i got a small air compressor separator from home depot.. i have posted photos on here somewhere in another thread.
bowtieman81
08-30-2006, 08:21 AM
Your method involves drilling another hole in the oil pan, correct? Also, wouldnt you need a check valve in the line that goes from intake to crankcase? If searched worked I would find your thread. I think I remember seeing it a while ago.
MIGHTYMOUSE
08-30-2006, 08:42 AM
no extra hole in the pan and yes on the check valve
one hose
intake -check valve -oil separator -valve cover
other hose
valley cover (or opposite valve cover)-turbo filter pipe
you will need to vary the size or quantity of the 'other hose' in order to not draw too much vaccum (may make crank seals squeal and suck in) and also to allow plenty of any crank case pressure to exit during WOT
bowtieman81
08-30-2006, 10:04 AM
OK, I am with you now Dave. I will start with 3/8" ID on the other hose since that is what I have.
bowtieman81
09-01-2006, 09:12 AM
Hey, I think my smoking issue has drastically improved. I tried the MM idea, seems to have worked well. I have a mess of hoses now :jest: , but it works.
I still have some smoking after letting off the gas after getting on it, but it is 50 times better than it used to be.
MIGHTYMOUSE
09-01-2006, 10:03 AM
cool man, just pay extra attention to your oil seperator and oil level.. you may go through some revisions so that no oil is ingested into the engine. i actually fouled a spark plug with my first configuration before i had an oil separator in there it was so much.
also it would be great if you could get ahold of another boost gauge or temporarily use yours to measure the vacuum in the crankcase AND watch that no positive pressure develops during WOT
also once you see how much vacuum you have, you can tinker with ways to get more vaccum = less smoke
lastly if the turbo is used you may just have a worn out one on your hands and needs a couple hundred dollar rebuild
bowtieman81
09-01-2006, 10:17 AM
I appreciate the advice Dave. I acutally used a fuel filter for my oil seperator, seems to work pretty good. Even if I have to change it out every 2k miles its only 3$.
So far it appears to ingesting very little oil, I guess I just had some crankcase pressure that needed to be gotten rid of. I will try and borrow a boost gauge like you suggested.
This turbo is supposedly fresh from a rebuild. Only has 250 miles on it since rebuild according to the seller.
I will pull a few spark plugs here in a couple weeks and see how they look. I need to get tuning on this now.
MIGHTYMOUSE
09-01-2006, 11:53 AM
its a real crappy feeling to drive around in a fresh $X,000 investment and have it smoke like a junker..i dealt with it of and on for years until i found my cheap solution.
bowtieman81
09-01-2006, 12:04 PM
Ya, I completely understand. It is even worse when people at the stoplights ask if your car is OK, or if it is on fire. For a guy that takes pride in his car it's quite embarrassing. :emb:
