god for-saken water spots
ive got these damn water spots on hatch glass and both windows and t-tops that i cant get off. please someone help i have tried everything short of battery acid!!!!!
It works best with 00 steel wool. You can remove the spots off of the tops, front, back, side, and mirrors. There was a thread about it already
Heres some more info on it
https://ls1tech.com/forums/search.php?searchid=3846266
I HAVE THE ANSWER!!!!!!! Eagle One Never Dull....buy at walmart! its in a silver tin can! THIS WORKS BEST to my knowladge...and iv tried everything! Im a carshow FANATIC and it gets my GLASS (not paint) looking like new! works amazingly on chrome rims as well
I had the waterspots from hell on my windsheild. Tried vinegar and all kinds of crap. I remembered that toothpaste polished up the plastic tailights good. So I tried it. Worked awesome, the spots are all gone. Just spread some on with your fingers, spray it with glass cleaner to thin it out and start rubbing it in with a cloth. When you wipe it off the spots will be gone. Didn't work on the paint lol
UNDER PRESSURE MOD
Take a rag and soak it in the vinegar mix and then lay it on the spots with the water spots. Let them sit for 5-10 minutes so it can dissolve the dried mineral deposits which is what water stains are.
You can also use a dilute mixture of CLR (calcium, lime, rust) and do the same thing. Just make sure you are careful around the paint.
I always treat my glass the same way I do my paint. It gets claybar'd, polished and waxed just like the paint.
will this work for me, i have some primer overspray spots on my t-tops. i tried a very light rough side of a sponge, and it SCRATCHED the glass. im thinkging steel wool would be even worse...
If you want to know how to get water spots out of glass...read my postings from this thread. A-MAZ is what will take them out....no problem....it will work like nothing you've ever seen!
https://ls1tech.com/forums/appearance-detailing/470854-help-water-spots.html
