1/2" head stud/cometic gasket question
My cometic gaskets won't go down over the 1/2" head studs. Is it ok to drill out the gaskets a bit? Anyone know what size to drill?
Will a single stud slide thru the gasket or is the hole under .500? Never have run into this problem. If the stud will go thru just tight, set the gasket on first then thread studs into block.
Kurt
Kurt
