Sponsored by: DashLynx
How do I get rid of this?!?! **pics**
Old 08-30-2006, 06:15 PM
Cakes's Avatar
Default How do I get rid of this?!?! **pics**
While I was doing my Berger panel I decided to remove my side "Z28" emblems because I am going vintage. They were very easy to remove however when cleaning up the final pieces of the double sided tape I noticed some "tape" I could not removed. Upon further investigate I noticed what seemed to me clearcoat over and old outline of tape. I know the previous owner had the front end painted when he removed the factory front ground effects so I am assuming that is what it is. I have (4) pictures below and I was wondering what I can do to remove it? Any help would be appreciated.
Old 08-30-2006, 06:19 PM
LS1_SS's Avatar
I know the GM dealers have the stuff to take it off with, I cant remember what its called though. Most autoparts stores should have it too, its a mild version of paint thinner from what I can remember.
Old 08-30-2006, 06:28 PM
ZaneO's Avatar
WD-40, Goof Off, Prep Sol, etc.
Old 08-30-2006, 06:34 PM
Cakes's Avatar
I should have clarified above better...the outline you see in the pics is actually covered by what I believe is clearcoat. I have gotten off everything I could using bug and tar remover followed by 3M rubbing compound, 3M swirl mark removed and 3M wax. Nothing I tried took it off.
Old 08-30-2006, 06:45 PM
LS1_SS's Avatar
wetsand? that would be your only choice, and if that doesnt work either repaint it or put them back on.
Old 08-30-2006, 06:46 PM
ZaneO's Avatar
Really difficult to tell from the pictures.
Old 08-30-2006, 10:42 PM
Jeremiah's Avatar
A repaint is your only solution if it has been cleared over. It will have to be sanded out, the clear coat feathered and probably lightly primed. Paint the erea, blend the collor and clear the whole panel.
Old 08-30-2006, 11:15 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Your doing the berger panal anyways you said? Who cares, sand and paint.
EDIT, just re-read, you said side..
Sorry man, just cover it up with another emblem.
Old 08-30-2006, 11:17 PM
98hardtopZ's Avatar
hes talking about the side emblems spuds...
edit: haha, just refreshed after my post and saw your edit...
Old 08-31-2006, 06:34 AM
The old man's Avatar
Like they said... Repaint. I had the same problem and worked on it for many hours to no avail... Needed a little painting done and just had it fixed at the same time.
Quick Reply: How do I get rid of this?!?! **pics**
