Manual Fan Switch?
Old 08-31-2006, 07:48 AM
02BEAST's Avatar
Default Manual Fan Switch?
Is it worth it to get for the staging lanes at the track?Do I need a lower thermostat to go with it?And one more ? how much lower will the switch make my engine get in the lanes?
Old 08-31-2006, 08:59 AM
LS69TA's Avatar
If you change thermostats, you need to either get the fan switch or have the fan settings changed in the PCM. I haven't done it yet, so I'm not sure how much of a difference it will make.
Old 08-31-2006, 10:18 AM
radz282003's Avatar
I don' t use one. The car cools off pretty quick. A lower thermostat would help, along with some tuning, but, you have to pay attention to not kill the batter, if you run them in the staging lanes, with the car off. I don' t really see the use, unless your intention is to run them with the car off.
Old 08-31-2006, 12:06 PM
chewy99ws6's Avatar
I have both, 160 stat, and SLP manual fan switch, I love them
Old 08-31-2006, 01:27 PM
98hardtopZ's Avatar
i did my own manual fan swith for 5 dollars and it works great...
Old 08-31-2006, 02:11 PM
parbreak's Avatar
How??
Old 08-31-2006, 05:09 PM
Chris95Z's Avatar
i don't think there is any significant power difference if any is to be had at all. I did mine because I was having heating problems with my fans not coming on. I spent about $20 but I also made it fancy so it wouldn't look ugly uder the hood or in the car. The way i did it was i just spliced into the hs/ls wires near my pcm and routed them to my switch and grounded my switch by splicing into a ground wire where my switch is. I can't imagine it being too diff on an ls1. you'll probably need to find some sort of schematic showing you where your fan wires are but basically you are for a start.
Old 08-31-2006, 06:33 PM
98hardtopZ's Avatar
you dont even need a ground... hold on ill find the linky...ill give you a dollar if you can find mine, my switch is in my ashtry and the one 18ga wire runs alongside the fender and you cant see it at all...
Old 08-31-2006, 06:48 PM
98hardtopZ's Avatar
here ya go...
http://shbox.com/1/fan_sw_diagram2.jpg
http://www.freewebtown.com/Loochy88/ManualFanSwitch.htm
http://shbox.com/1/fan_switch_wires.jpg
Old 09-01-2006, 12:19 AM
Flawless02SS's Avatar
Its def worth it. And it wont run your battery down in the staging lanes, unless you have a POS battery. I've ran mine for 45 min before by mistake.
Old 09-01-2006, 09:55 AM
sickws698's Avatar
if your about to get a tune cant they program somthing with the fan
